Forgot to winterize
A lot of enclosed buildings stay 38-40 all winter depending how tight they are, regardless of having insulation or not. I proved this to a few friends a couple years in a row with a thermometer, a glass of water and a 24' Baja that I didn't winterize. I did turn it over a few times because the impeller will bond itself to the housing. I think you're ok but I'd at least put a trouble light in the engine hatch for cold weather. Like I said, this depends how tight the building is!
That sucks. It takes about 2 min to winter the 496. I did a buddies a few weeks ago and it was just in the nick of time. Water was slushy, when I drained it. That was shortly after Thanksgiving.
I keep mine in heated storage, and still drain the water from everything. I'd be heading over there tonight, and checking it out.
Is the 32 that just arrived this summer?
sorry to hear that.
sorry to hear that.
It could be above freezing in the engine compartment for a number of reasons. If there's power out there, or if he can run an extension cord I would heat the motor compartment with a small heater until the next day that it's bearable inside. At that point try a to winterize, worst thing you can do is figure out that you have a problem early.
Yeah, what they said about the closed cooling. The block should be filled with anti-freeze
unless some tool put water in there
. Heat exchanger is probably shot and they are not cheap. I would warm it up (not by running) and pull the drain plugs and pump air into the system which is all it takes to winterize the 496. Hopefully the exhaust had drained. Short answer, engine is fine. Raw water side not fine.
Up til about a couple weeks ago it might have been
ok, now, it's definetely done.
Except that usually when a manifold cracks it leaks water into the cylinder and rusts the rings to the walls etc..
If you guys trust that air system alone you will live to regret that.
You'd be surprised by how much water stays in that system. The air drains are kinda like idiot lights in your car...
You're an idiot if you trust them.
And by the way - I'm not bitter....
Merry Christmas!
Merry Christmas!
