Difference between an HP transom assembly and a Std Bravo >
Old 01-12-2011 | 01:32 PM
berns29scarab's Avatar
Default Difference between an HP transom assembly and a Std Bravo
I've been reading all the previous threads i could find and it seems every thread staets something different EXCEPT all agree on diff hinge pins. I was under impression that the HP assembly had stainless pins n the std did NOT, and also the the overall gimbal itself was a beefier piece.
WHAT are the real diffs??? Now you can order an HP assembly wither with out without trim senders also.
berns29scarab is offline
Old 01-12-2011 | 02:04 PM
glassdave's Avatar
Neno the mind boggler
Yea, I believe the gimbal ring and the bell are heavy duty and that's about it.
08 OPA High Points Champion
glassdave is offline
Old 01-12-2011 | 02:07 PM
There are a few companies that make stainless gimbal rings like Hill manufacturing. They might be the strongest and priced the same as Merc. I was told the bell was no different. I thought you couldnt get trim senders on an HP? Somebody please chime in, I am in the same process as berns29scarab
Keith Atlanta is offline
Old 01-12-2011 | 02:13 PM
Here are the HP transom assembly part numbers
Without senders 6-6511002NZ
With Senders 6-6511102NZ
Old 01-12-2011 | 02:16 PM
http://www.mercruiserparts.com/Show_...ages/COMMON/NO IMAGE&inbr=11406&bnbr=40&bdesc=Transom+Assembly+Ch art
Old 01-12-2011 | 02:18 PM
6-6511002NZ TRANSOM ASSEMBLY, Hi Performance Without Sender $3,456.17 $2,976.80 1
- 6-6511102NZ TRANSOM ASSEMBLY, Hi Performance With Sender $3,456.17 $2,976.80 1
Old 01-12-2011 | 02:33 PM
Call Ron Bender at JR Marine and see what he has to say about the differences, he may even have the parts your looking for. He saved me a lot of money last spring.
BGIII is offline
Old 01-12-2011 | 05:24 PM
Dave knows what I have done (or should I say gone thru) to have a beefy Bravo gimbal assembly. The stainless gimbal ring is a Max Worx part.
http://maxmachineworx.com/accSstGimbal.htm
One nice piece but still needed a little TLC with the grinder to clearance the Merc HP Bell Housing.
Yes, you can still use the trim senders. The link that was previously provided shows the parts required.
NOTE: You do need to purchase the Merc Module #884359T1
for your trim gauges. My understanding from Merc is this is required regardless of whether Smartcraft or analog use.
Special Note: If you were thinking of using IMCO parts, be very careful. Only specific parts that are designed for Merc use will work. The good IMCO rings and bells only fit into IMCO mating parts. A call to IMCO for part compatibility is highly recommended. I did, after the below happened.
This knowledge of IMCO drive parts comes from a painful and costly f***ing from an OSO Marine Supplier. Thank you.
ROTAX454 is offline
Old 01-12-2011 | 05:38 PM
seafordguy's Avatar
I don't know but my TA's have the bigger (about 1 inch diameter) SS pins that are pounded in and removed with a slide hammer. They do not have a place for the trim senders so you have to get the ones that mount to the side of the trim rams.
seafordguy is offline
Old 01-12-2011 | 06:40 PM
About a grand
FIXX is offline
