Help!!  Dented CMI Headers!! >
Old 01-15-2011 | 08:24 AM
Default Help!! Dented CMI Headers!!
Anyone have any suggestions on how to fix these headers for Cheap. The dents are right on the top side in plain sight too....They are CMI's for a V10 Ilmor that I just bought...
Thanks, Derek
bullittcustoms is offline
Old 01-15-2011 | 08:45 AM
Skatermac's Avatar
Fill with water then pressurize with air try 15psi. Heat with torch. No guarantees. Will work on thin metal some signs of the dent will still be there. Re-polish when happy repair. Good luck!
Skatermac is offline
Old 01-15-2011 | 08:50 AM
offshoredrillin's Avatar
if they were damaged in shipping then file a claim with the shipper and get a new one.
offshoredrillin is offline
Old 01-15-2011 | 08:59 AM
Had UPS bent the same prop twice, What can Brown screw up for you today.
Good question , did they arrive that way?
Donzi Dude is offline
Old 01-15-2011 | 10:04 AM
They were put inside a boat we had delivered and were boxed when we got em. They went from the guy we got them from to inside the cockpit of a daytona to my shop floor when we opened them. The guy I bought them from just failed to mention they were beat all to S**T..... I wonder if CMI will fix for a reasonable price?
Derek
Old 01-15-2011 | 10:16 AM
Comanche3Six's Avatar
Derek
Derek
CMI has to cut them apart and install a new tube. Sorry for your misfortune.
Ed
Comanche3Six is offline
Old 01-15-2011 | 11:15 AM
Since the damage is near the open end, find a good automotive paintless dent guy. They have a bunch of special shaped tools that can pretty much get anywhere. They can probably pop those out with no problem. Jeff Wurl
jwurl is offline
Old 01-15-2011 | 12:40 PM
Tig weld on some welding rod peices and use a slide hammer and heat, similar to a body shop pin puller dent remover. I would just try and get it opened up for water flow, then maybe a carbon fiber accent panel the covers the bump for some added bling. Good Luck
Boat1 is offline
Old 01-15-2011 | 02:47 PM
c_deezy's Avatar
Exactly. Should be able to pull it out quite a bit.
Or if its only the outer tube, and just the one on the top you could slice the outer tube off, knock the dents out and then tig it back on. That way if the inner is dinged, when you pull the outer off you could fix the inner too.
c_deezy is offline
Old 01-15-2011 | 03:12 PM
+1
This is the only repair method that I can see working. 15lbs. of air pressure and moderate heat isn't going to do anything to those headers.
wjb21ndtown is offline
