Any boats with a single diesel? >
Old 03-15-2011 | 01:36 PM
Stormrider's Avatar
JC Performance Engines
HJ, how would a 5500-6000lb single 350hp diesel w/ a direct 1:1 drive be around the docks?
600rpm w/ a big prop could really lurch a light weight boat, no?
Maybe you'd need a trolling valve for slippage?
Stormrider is offline
Old 03-15-2011 | 02:48 PM
Yes it will jump pretty hard, a trolling valve really helps.
The little Malestrom we had the Cummins in with direct drive jumped pretty good. It's was almost like a crash box, in gear for a second and pull it out, it would go pretty fast if left in gear.
That's why i always like the little props turning faster, they don't grab so hard, you get better top end but you do loose slower cruising speeds.
HabanaJoe is offline
Old 03-15-2011 | 03:39 PM
bor's Avatar
bor
I have a 32 hustler whit a pair diesels on xr drive 1:50 turning 34 bravo's and I can tell you that that's going quite fast on the docks !
bor
bor is offline
Old 03-16-2011 | 12:05 PM
Default Single w/diesel
Hustler did build a 26 with a single Yanmar 315 HP ran low 50's top end. Talked with the factory yesterday and he would do it again or if you wanted they would do it in the new 29 Rockit also. Speed in the 29 would be about the same due to a more efficent bottom than the 26. Low 50's top end and cruise in the mid 40's. Call or PM me if you need any more assitance.
George
Anchor Performance Sales
cell 847-323-0039
Hauling Hustler is offline
Old 03-16-2011 | 02:29 PM
HH - I usally don't try to disrespect someone but if Hustler can only get that kind of speed, they are doing something wrong. I'm guessing there is more HP available then they are putting to the water.
Do you know anything about the 39 Rocket they had at the Miami show? I saw it on 440 going back to LI and on their facebook page i asked a few questions about gearing etc but did not get an answer - just curious how that boat was set-up?
Old 03-16-2011 | 03:30 PM
There is one for sale here http://hamble.boatshed.com/hustler_2...oat-35117.html
The add claims 48 knots as top speed, which is 55 MPH.
Phazar454Mag is offline
Old 03-16-2011 | 03:34 PM
Talked to the Hustler people at the Miami Boat Show.
They have std 6,7-450 engines and hoped for 550 with another ECU.No ECU,s in the boat at the show. Cummins still worked on them.
No 2-speed and std NXT-uppers with #6-lowers. Think they had 1,35 gearing and would also test 1,15 (1,18?). The boat needed some more hours of work before seeing water.
One of the guys was talking about 100 mph...
7075T6 is offline
Old 03-16-2011 | 05:08 PM
Rik's Avatar
Rik
arneson-industries.com
Offshoreonly Advertiser
Joe, you know one cannot dock a boat with the "trolling valve" engaged as anything above idle speed and the trans will smoke
Arneson Surface Drives www.arneson-industries.com
Rik is offline
Old 03-16-2011 | 05:50 PM
RIK - your right, I'm looking at it from how I dock a boat. I almost never needed throttle even on my big boats, the 34' SH we had with the 1.15:1 you never needed to ever give that boat any throttle to dock. I think the trolling valves could have been an asset with that boat?
But, you are right the trolling valves can't take too much power.
Old 03-16-2011 | 06:46 PM
If they are running anything like that for gearing unless they have some major OD gears, bigger than ZF has standard there is no way that boat could come close to 100 mph, just not enough prop speed.
Look at anyone's boat on here that runs a 100mph, and calculate the prop speed. If it was possible to do it by turning the prop slow then everyone on here from Fred K himself would do it, but they don't.
A diesel is not magic a boat responds to prop dia, pitch speed, drive height, etc - the boat knows not whether it has gas or diesel power in it. Too many people don't follow the same basic principles of how they set-up a gas boat and that is the only reason the diesel boats don't go better than they do!
