Airplane People
Come on guys. If it has a little visible ball in the top center. Its a grease zerk fitting. If it is hollow in top center, it is a bleeder port like your trailer or car brakes. I think. I have been wrong many times before. LOL
Charter Member#203
The actuator shown is a simple two way acuator the has a o-ring around the piston and it gets lubricated via the oil/Hydraulic fliud used in operating the device. It is a grease fitting for the bearing, that may have been there before under original design.
I'm thinking it was a bleeder and somebody for some reason screwed a zerk fitting in it. Needed something to plug the hole to go boating for the afternoon and never got replaced. Possible? Not that I would ever do that.
Doug
Doug
Sorry but both of them are like that and this is a race boat so it wasn't like they didn't know they were going to take a ride at a certain time.
Put a wrench on it already and end the missionary...
Having been aviation for 22 years, worked on fixed wing and helos, both flight line and component repair, I have NEVER seen a actuator need grease on the top of the piston.
I have and work on mech and hyd punch presses that over 70 yrs old. The way the equipment was over built then to what it is now dont even compare to each other.
