-   -   Airplane People (https://www.offshoreonly.com/forums/general-boating-discussion/249596-airplane-people.html)
Boater8987 03-19-2011 08:58 AM
Is this how they debate over $10,000 toilets in congress? Now I know why nothing seems to change within our government.
:lolhit:
handfulz28 03-19-2011 09:17 AM
Aunt Flow says it's a bleeder...
Looks a lot like the top of a grease gun....which has a bleeder. Think of the machining to make a passage to the pivot pin versus it being a bleed point.
bobonthis 03-19-2011 12:46 PM
I have another question about the picture. What are all the bolts going through the hull for? Are those to patch bullet holes?lol..
RunninHotRacing163.1 03-19-2011 01:17 PM
:lolhit:
why yes it is .....:lolhit:
f_inscreenname 03-19-2011 03:24 PM
cause it's a 1968 Race Boat and there is a lot going on back there.
http://img291.imageshack.us/img291/3383/65393488.jpg
Like 2 trim pumps, 2 steering mounts (twin cable steering), lifting eye mount (not like I would ever use it to lift the boat but it's there), fresh water inlet for flushing, twin trim ram mounts, rocker tabs mounts, sea water pick up, rudder assemble, stern light, 2 of the 4 exhaust ports, scupler cable mount, tie downs .....I think I missing something.........anyway you can see there is a lot going on back there.
This side is even worse.
http://www.supernova19.com/9cdf4780.jpg
TMITCHELL 03-21-2011 02:16 PM
f-nscreenname, what I see is a grease fitting. If you follow the housing back from the fitting if it is a grease fitting for the pivot point (original application) usually the casting for a passage way is visable in the casting. Let me if you want me to stop and have a look.
Tom
RunninHotRacing163.1 03-21-2011 03:15 PM
Tom
DING DING !!!!!
WINNER WINNER CHICKEN DINNER :drink::drink:
MidOcean 03-21-2011 03:59 PM
My guess is, considering that the ram's original design was for the main gear strut of a Cessna 210, that it is a grease fitting that is plugging the hole left by the gear lock indicator that was obviously removed when the ram was converted for marine use.... which means, the journal should lead to the hyd fluid side and not to the pivot pin...
Let me know what I win if I turn out to be right....
f_inscreenname 03-22-2011 04:33 PM
And a drum roll please............................................ .................................................. .....................
Grease fitting for the top pin.
Took a little bit delicate surgery to find out but I didn't break anything so all is good.
Thanks for your help everyone.
