Vinyl Cleaning
#31
Try Bleach White. Spray it on a wet rag and rub. It took every stain out of my seats. The deniem blue jean stains as well. You can get it at any auto parts store.
#33
Registered User
WOW what a plethora of products!!!
Ive used simple green before, however, i have noticed some of the color from my vinyl coming off on the rag!!!!
So this is why I asked this question.
I have used other meguires products before on cars and trucks, I noticed today at west marine that they have a "marine/RV" vinyl and rubber cleaner and protectant. Deep cleans, restores, and protects from UV damage.
I value all of your reccomendations and advice. Nothing speaks like experience!!
So, do I try the stuff from meguires?? Or go with what the offshore boyz are telling me about the 303????
hummmmmm???
I'm still confused!!
hummmmmm???
#35
hummmmmm???
hummmmmm???
#36
Registered User
#37
Registered User
From a protectant standpoint, there is simply nothing better than 303 Aerospace protectant. Just make sure you use enough to let it soak into the stitching. Some of the cleaners mentioned here (Lacquer Thinner for instance) scare the hell out of me and will destroy your vinyl by removing all the plasticizers. Others will "clean" the vinyl, but rot out the stitching over time. So, using a high grade product like 303 will at least minimize any damage to the stitching and protect your vinyl.
#38
OK, I've tried just about every cleaner in existence. The best vinyl cleaner I have used is Spray Nine. Dilution is not required. For a little more cleaning power, use Spray Nine with the Magic Eraser. The Eraser is slightly abrasive, so watch out when using on colored vinyl. You can use them together for extra cleaning power. You can also use the Eraser without Spray Nine. As other have stated, follow up with 303.
You can use agents with bleach, but use sparingly, as the bleach will dry out the vinyl and stitching.
Whatever you use, I would use use 303 as the finishing application.
#39
