Boat wanders side to side at idle speeds, Why? >
Old 04-08-2011 | 10:08 PM
  #31
Registered User
Originally Posted by dicudmore
Dave congrats on the new to you ride
-Dan
Thanks Dan.
Dave
Dkahnjob is offline
Old 04-09-2011 | 01:45 AM
  #32
My 25ft single engine V hull did it really bad when I would idle through the channel. I hated it!!!! But it was fine when I was not idling. I have a cat now and it is straight as an arrow
Wet-N-Wild is offline
Old 04-09-2011 | 01:52 AM
  #33
Randy Nielsen's Avatar
Would it make any difference on a twin setup if the props turned in or out?
Randy Nielsen is offline
Old 04-09-2011 | 06:40 AM
  #34
Both of my twin engine side by side boats did it. The 30' was worse than the 35'. My 370 is bad too. The gladiator is staggered turning in, nice and straight. The first two boats had hydraulic steering too.
redbud35 is offline
Old 04-09-2011 | 06:51 AM
  #35
I have had singles and twins and the single engines all wander more that the twins. It's something you get used to in no wake zones. Often times I am messing around when coming in and my wife says it does that to keep me seated and at the wheel instead of walking around on auto pilot not paying attention
ElimiNordic is offline
Old 04-09-2011 | 06:58 AM
  #36
Mine does it too. I have the toe set out less then 1/8". Checked all connections and bushings and everything was tight. Figured thats just the way it is. I did add tabs last year and that has helped when they are lowered.
capt2130 is offline
Old 04-09-2011 | 07:00 AM
  #37
Mine says the same thing.
capt2130 is offline
Old 04-22-2011 | 07:43 PM
  #38
Registered User
Wink Problem Solved
I thought I would post the results of what I found and what worked.
I spoke with Jerry Barron at Hallett boats and he said that the drives should be exactly parallel, mine were toed out more than 3/8". So I adjusted the tie bar so that they were exactly parallel. That fixed the problem by at least 50% or more.
Then I put the K-Planes all the way down while idleing as recomended one of the posts. The end result is that the boat now tracks straight as an arrow and has no tendency to wander.
There is about an 1/8 turn of play in the mechanical steering cable, so I am going to go with an Imco full hydraulic set up and then I think I will be 100% good.
Thanks for all of the input.
David
Dkahnjob is offline
Old 02-08-2012 | 03:29 PM
  #39
My Hammer also wonders at idle.....and yes typically if you point it in the right direction and let it go, it will wonder in a straight line....believe it has a lot to do with hull design...that is if your steering is tight.
jlbspd is offline
Old 02-08-2012 | 04:05 PM
  #40
All single engine V's wander due to prop torque
machloosy is offline
