lorviorsi gps batt change??? >
Old 04-19-2011 | 01:40 PM
Registered User
I also will be trying to get it fixed this week, I hope this works then my boat will be 100%!
sunsation96 is offline
Old 04-19-2011 | 02:50 PM
Quinlan's Avatar
I cant even get the cover off mine. Do they unscrew or just pop off?
Quinlan is offline
Old 04-19-2011 | 02:55 PM
unscrew
boatnt is offline
Old 04-19-2011 | 08:19 PM
Default Replace with a Garmin antenna
I just replaced mine with a Garmin GPS17-HVS antenna.
Red to red
Black & Yellow to Black
White to orange.
No more battery issues in the antenna.
THERUSH is offline
Old 04-20-2011 | 05:41 AM
ACTIVESHACK's Avatar
Originally Posted by Macklin
What a PITA design!
Livorsi and CMI are owned by the same company
ACTIVESHACK is offline
Old 04-20-2011 | 07:49 AM
I am going to try to replace the batt,still can't gewt the unit apart,will see what happens thnks for all the input
park35 is offline
Old 04-20-2011 | 05:42 PM
Has anyone tried their's after they installed a new battery. Livorsi said the older ones need to be recalibrated also.
So I brought them my dead one and ponied up for the replacement antenna for my series Speedo.
Back4More is offline
Old 04-20-2011 | 06:03 PM
Red to red
White to orange.
Next time I just might try that...wiring it to my Garmin output leads.
Old 04-20-2011 | 09:14 PM
How do you wire it to your Garmin. My gps speedo is not working either and i was told to send it to livorsi and they'll send it back fixed. I figured I'll leave it dead since I have a very nice Garmin..
dodgeman111 is offline
Old 04-21-2011 | 05:39 AM
Dave M's Avatar
Veteran: Navy
Real easy, connect the blue wire from the gps harness to the signal wire on the speedo. Then go into the "Comm" menu on the gps and make sure NMEA output is selected.
Dave M is offline
