Center Console Ideas
Old 05-06-2011 | 09:37 AM
Statement Marine has expanded into the Center Console market, with multiple Center Consoles in production as we speak. 2 Diesel 37's and 2 outboard 34's. One of the outboards is still available. 10' beam, 34' length, twin or triple outboards of your choice.....priced right! Custom built to your specifications. Stepped bottom, twin 300 Verados runs 65mph.
Statement Marine only builds state of the art boats, top of the line quality and impressive attention to detail and outstanding performance!
www.statementmarine.com
727-525-5235
Statement1 is offline
Old 05-06-2011 | 01:34 PM
THEJOKER's Avatar
Originally Posted by fantastixvoyage
Are companies doing the console as part of the liner or as a seperate piece?
Ours is a seperate piece. Aluminum L brackets , lagged in the stringers and glassed in from the inside. This supports a huge Birdsall Hardtop.
THEJOKER is offline
Old 05-06-2011 | 01:37 PM
THEJOKER's Avatar
Build a big sunpad for the girls to lay out on. Then make the storage area under it so big blocks or Yanmars can fit under there.
THEJOKER is offline
Old 05-06-2011 | 01:41 PM
THEJOKER's Avatar
This shows the sun pad better.
THEJOKER is offline
Old 05-06-2011 | 08:13 PM
THEJOKER's Avatar
Storage area under the sun pad. The entire area is all a finished part.
THEJOKER is offline
Old 05-06-2011 | 10:22 PM
Originally Posted by wananewboat
Has a Poseidon 2 been built with twin 300s and if so what would the speed be?
We shut off center motor and it still ran in the 50's
marine concepts is offline
Old 05-07-2011 | 07:35 AM
Originally Posted by marylandmark
Pete- 32'6 is the LOA which includes the bracket. 30 hull with 2'6" bracket. USCG makes them measure so.
Originally Posted by Pete280
somebody believes it's a CG requirement
Above measurements are for my Concept 326. The bracket has to be counted in the documented length per the Coast Guard because it "contributes to the flotation".
See in this pic, how the bracket is not just the platform one stands on but also has "hull properties" (my word for lack of knowing what else to call it).
My terms may be wrong, like LOA should include every thing including motors, where LWL is length at water line and LOD is length on dock and so on; either way no matter what one calls it, the hull is 30' and the bracket is 2'6". I'm 37' on trailer which means it fits in my garage which is good 'nuff for me.
marylandmark is offline
Old 05-07-2011 | 09:07 AM
bcschoe's Avatar
BRAD SCHOENWALD
I just had to put this here:
http://imaximaxges.smugmug.com/Offsh...539_z5Mcx-A-LB
bcschoe is offline
Old 05-07-2011 | 11:57 AM
dkwestern's Avatar
What's it run with all 3 300's?
dkwestern is offline
Old 05-07-2011 | 03:41 PM
Mid 60's, and get there right now! 12,000 pounds
