-   -   Water Preesure HELP! (https://www.offshoreonly.com/forums/general-boating-discussion/253236-water-preesure-help.html)
29 sst 05-10-2011 06:51 AM
Ive recenty went from -2 imco to -3 and have experienced high water pressure. When im running say under 80 its fine, around 20-25 psi but once I get over 100 its like 35+. Im worried i might push a head gasket to far. Ive heard of adding dumps but im not sure how. any info is appreciated.
Phill
JasonSmith 05-10-2011 11:44 AM
You need pressure relief valves added. I put mine in after the sea pump but before all the coolers.
Eddie Marine sells them:
http://www.eddiemarine.com/store/car...&p=13372&c=238
Dueclaws 05-10-2011 12:16 PM
An OSO member has some new, but old stock relief valves for sale. Contact Rob: [email protected]
bobsbillets 05-10-2011 12:28 PM
Thanks John!
29 sst 05-10-2011 04:01 PM
Does anybody have a kit for 500 efi's
Sport 280 05-10-2011 04:09 PM
Do not think there is a kit. Just purchase the relief valve, plumb it in the hose coming out of the engine water pump, then run dump line out side or back of boat. I used the relief valves made by merc., a little expensive, but way cheeper than replacing a head gasket.
Make sure that winter layup includes draining the dump line at the relief valve.
Merc
Water pressure relief valve
863208a3
cloudmaster_321 05-24-2011 01:04 PM
My Merc water pressure relief valve is connected inline of the water from the drive to the sea water pump. Is this not the way it should be?
US1 Fountain 05-24-2011 01:06 PM
Mine are right before the circ. pump. Using teh Merc valves. Those things are worth their weight in gold. And priced so too! :)
cloudmaster_321 05-24-2011 01:24 PM
Anyone have any specific installation procedures for these valves that show where they are supposed to be? I'm wondering if it really matters.......
cabin fever 05-24-2011 04:51 PM
i just ordered the one from Eddie Marine. Save yourself $30 and order it from hardin marine.
