Starters not engaging flywheel? >
Old 05-16-2011, 09:00 AM
Forum Regulator
Sydwayz's Avatar
Received 1,212 Likes on 525 Posts
Default Starters not engaging flywheel?
What's the trick to get the starter to engage the flywheel? First start this morning, and neither one of my starters will engage on 496HOs.
Thanks in advance!
Sydwayz is offline
Old 05-16-2011, 10:51 AM
Registered User
A hammer!
Bathtub is offline
Old 05-16-2011, 10:55 AM
Forum Regulator
Sydwayz's Avatar
Tried that. Tried a little WD-40 on the shaft too. (keep your mind out of gutter, KY didn't work either) No luck.
Poker Run this weekend, and luckily I found someone down the street who is installing new starters for me tomorrow.
Sydwayz is offline
Old 05-16-2011, 10:59 AM
OSO OG
DollaBill's Avatar
either bad soleniods or low amps.
DollaBill is offline
Old 05-16-2011, 11:05 AM
Pwrbt33's Avatar
Awesome, looks like I dont need to call now. Good luck!!
Pwrbt33 is offline
Old 05-16-2011, 11:42 AM
rchevelle71's Avatar
I think OCDactive had some better lube
rchevelle71 is offline
Old 05-16-2011, 12:25 PM
Forum Regulator
Sydwayz's Avatar
Thanks John. Austin did call me back. I'd be on my way there if the guys from 20 minutes down the road couldn't get me in. Thanks for the follow up!! I always call you guys first.
Sydwayz is offline
