Trying to get rid of porpoising
You need more bow lift that is why your getting the porpose.It can't carry the bow and it falls it's better in rough water and worse in flat right? You can try to spin the drives in that might help. I would try to find a set of 16.5 x 25 or 24 three blades that would probably work. It's going to be hard to find props in the smaller pitch sizes in the 3's they are just getting hard to come by.
Depends on the prop, they are all designed for different lift, bow/stern/neutral. I personally would try the 4 blades first, depending on what they are. I am running 3 blades, and get a bit of porpise at slower speed because they cant quite carry the bow and it falls on its face. Throttling up past that point makes it go away. I was told 4 blades would help a lot (Bravo 1's)
I have a 271 sr-1 Formula that I'm going through the same stuff right now I have a labbed 24 B1 4 blade that does no porpose and a 25p Mirage that is porposing and I just Overreacts to trim in the rough stuff. Top speed is better w/ 3 blade but overall I like the 24p Bravo One. IMHO
you want the biggest diameter the boat will allow meaning that you want to keep in increasing the diameter until the boat starts to chine walk or act stupid. when it does this, it means the stern is lifting to much. i will explain more later, have to run...
