Power Steering Fluid
Old 05-25-2011 | 08:24 AM
Default Power Steering Fluid
I noticed my power steering fluid is low on my boat. I have a 454 MPI. I don't remember what type of fluid it says on the top of the motor cover to use, so i was hoping somebody could help me out. Do I need to use the Mercury fluid that it tells or could I pick up something that may be a bit less expensive?
svt_22 is offline
Old 05-25-2011 | 08:36 AM
Ted G's Avatar
I have always used standard PS fluid from the auto parts store with no issues, it is a GM pump so normal PS fluid is fine. In a pinch you can also use ATF. But PS fluid seems to be better for the seals.
www.cbpba.com
Ted G is offline
Old 05-25-2011 | 08:41 AM
Yea. kindof what i was thinking i have some fluid somewhere for my truck. Thanks for the help.!
svt_22 is offline
Old 05-25-2011 | 08:49 AM
I called imco on this and they told me standard power steering fluid. I believe my manual says the use of 10/30 motor oil is fine.
JRider is offline
Old 05-25-2011 | 08:53 AM
Ted G's Avatar
10w30 can be used in tabs and trims, but I would avoid it in the PS.
www.cbpba.com
Ted G is offline
Old 05-25-2011 | 10:19 AM
x2...that is what I have been told.
1MOSES1 is offline
Old 05-25-2011 | 11:57 AM
Regular PS fuid or transmision fluid will work fine.
Griff is offline
Old 05-25-2011 | 12:28 PM
Have always used ATF in any power sterring pump that I have ever had. Not saying it correct tho
drpete3 is offline
Old 05-25-2011 | 12:32 PM
Fountain4402's Avatar
mine was emtpy and just filled it with STP it also was blended with seal conditioner
Fountain4402 is offline
