The difference in Outdrives
Bravo One,Bravo 111,X drives, XR drives??Drive showers??I'm sorry Guys I'm totally new to all this and I want to know as much about this stuff when I buy a boat..Thanks
Most GO-Fast boats are going to have either Bravo Ones or Bravo XR's.
The XR's are supposedly a little tougher than the Bravo 1's but the guys on here still manage to break anything Mercury throws at them. All Bravo Variants will not have transmissions inside the boat, they will be in the drive itself. Bravo III's are dual props, but you rarely see them on Go-Fast boats - they are usually on cruisers. Alpha's are weaker drives that you will usually see behind Small Blocks. TRS are tougher older drives that Mercury no longer makes. They have tranmissions inside the boat that attach to the back of the engine. Drive Showers are nothing more than a little mechanism that shoots water up and drops it on top of the drive - they help cool the transmission that is in the top of Bravo and Alpha drives. |
Ssm
Originally Posted by seafordguy
(Post 3415750)
Originally Posted by O.C.Barry
(Post 3416704)
There are also replacement drives like Konrads
It all depends on what size and type of boat and how much HP. My Bravo X lasted 7 hours after my repower with the 525 in a 22 foot boat. The XR is on it's third season. The X was fine behind the 496 HO. Now in a larger boat with bigger HP I'd forget the Bravo entirely. That's my experience and about all I can add to this thread.
TRS vs TR
But where does the TR fit in? Compared to the TRS?
What would be a better choice to to replace the TR/TRS a Konrad or a Bravo (assuming you patch up the hole). -BL |
@dukhntr
Never heard of a Merc TR drive. The Bravo1 is rated to 500hp and the XR is rated to 600hp. If you buy a cat you can get away with a lower rated drive because less of the boat will be in the water at speeds higher than planing speed. V bottoms tend to be harder than cats on drives. If a seller tells you his boat has the SSM 3 drive, ask him if it's the 3A which has stronger shafts and is more desirable. Welcome to OSO and I hope this helps. :) |
and also remember Arneson asd-7 is the remedy for all broken bravo's...
and ASD-8 can handle more power than #6's... |
the TR drive was exactly like the TRS drive and made the same years. The difference was, the TR just had a longer leg(lower-unit), so as to swing a larger diameter prop, for cruisers, houseboats, etc. The same difference that the Bravo One and Bravo Two have today.
Konrad makes direct replacements for both TR and TRS drives. Bolt it on and go.
Feel free to shoot me an email for more info. [email protected] |
| All times are GMT -5. The time now is 01:09 PM. |
