HEADERS: Lighting,CMI,Hardin,etc >
Old 08-03-2011 | 10:08 PM
My buddy's cmis just leaked for a second time in 5 months. The first time it toasted a 525, he has them pressure tested every time he gets the oil changed. Guess what? Same header, same place that cmi just repaired leaking again. Guess what? Cmi does not warranty any repairs they do. Great company. 5 months on their repair and won't stand behind their product. Says everything doesn't it.
rchuntlsl is offline
Old 08-04-2011 | 12:24 AM
Wink
Easy to answer question> You've got Kieth Eickert engines, use his beautiful 4 tube sweeper cast headers. they make great power. look great and they don't leak! Easy answer!
Best Regards,
Ray @ Raylar
Raylar is offline
Old 08-04-2011 | 12:54 AM
Default Fixx
Stellings or KE header manifolds period!
Cmi uses 316 SS welding rod on their headers and stelling uses 317 SS welding rod on their headers..317 rod is better in salt water and less prone to crack..
scroll down and read about it..
http://www.alcaminc.com/stainless-inconel-monel.html
FIXX is offline
Old 08-04-2011 | 06:11 AM
BONDO10's Avatar
Can the same tailpipes be used if going from CMI,s to Stellings? Are they a direct fit replacement? Thanks
BONDO10 is offline
Old 08-04-2011 | 07:54 AM
4195's Avatar
Can You Hear Me Now??
Best Regards,
Ray @ Raylar
Ray I am running the boat in salt water will that be a problem for all aluminum header? Are they coated? As far as Stellings go I heard they are no longer producing headers, anyone else hear that?
4195 is offline
Old 08-04-2011 | 08:14 AM
scarabman's Avatar
I have 11 yrs (knock on wood) on my KE,s in a salt water enviroment. Still going!!!!!!!!
scarabman is offline
Old 08-04-2011 | 08:31 AM
I have CMI Gen X on my rear/port motor, second set, first set leaked, cracked and pitted after only 3 hours of use. i'm done with CMI, so another local O.L. guy here on Long Island recommended Stellings, he claims no problems. I called Stellings yesterday requesting information. Apparently, they are phasing out their header product. They are hand made and and family run/owned, they phasing out due to age and retirement of skilled staff. But, are still willing to mfg. custom headers for the near future. She quoted $6,000 per motor. That is heavy........
Redmen666 is offline
Old 08-04-2011 | 08:51 AM
SS930's Avatar
Still cheaper than buying multiple sets of CMI's or gernading an engine! Get them while they're still making them!
SS930 is offline
Old 08-04-2011 | 08:57 AM
Just to throw this in the mix. What about the Hardin headers? Good or bad?
A.O. Razor is offline
Old 08-04-2011 | 10:25 AM
i have 525 direct replacements from hardin,,,made by lighting,,,you can use the cmi tailpipes,,,frank dont know your head bolt pattern,,,on the 675,s by KEITH ,,,but iam very happy with them so far,,,
TWIN-SPINS is offline
