Bravo XR Capabilities?
#61
Why do you think the NXT and Konrad is a better option than the Arneson? The rigging involved is atleast the same, as the ASD#7 for the Konrad and probably more with the NXT/#6 package. What is the price for a complete SCX, Konrad or NXT/#6 drive, including steering ect.? Also, with the SCX and Konrad, you don't get the speed and handling advantages of the surface drive. Is the Indy drive available as a drive only, and how does that compare price wise?
#62
I cant understand how Konrad would be a good alternative to a bravo or xr when an SCX or BMAX is plug and play. No transmission to deal with, no pulling motor, no rerig...just seems like an SCX or a BMAX would be a logical choice. I believe you need to use the Hi-perf merc gimbal with either but if your coming from an XR its already there.
#63
I cant understand how Konrad would be a good alternative to a bravo or xr when SCX is a plug and play. No transmission to deal with, no pulling motor, no rerig...just seems like the SCX is a logical choice along with BMAX. I believe you need to use the Hi-perf merc gimbal with either but if your coming from an XR its already there.
#64
What is the deal with the Xpower? I have only read about 2 boats with them and one of them was on their own web site. I think they priced themselves out of the market...would have thought that they would come in between a SCX and Arneson.
The details on the Xpower are pretty foggy as well...
Does it come with its own gimbal? Or does it bolt to a Merc? Does it have a cone clutch setup or does it need a tranny? If it needs a tranny can it go in and extension box? Does it come with a tranny? Their site is not very informative. However...it does talk about their "Top Secret X-dimension"...in the vids it doesnt look so secret to me...looks like the waterpickup is not in the front of the bullet but rather on botom of the gear housing by the leading edge of the skeg...Allowing extremely hight X. It may be a great drive but at that price, why not an Arneson or a 6 / NXT?
#66
Another thing I like about an SCX or Bmax is that you can use your existing lower/s. I know on the Bmax it involves swapping in a larger lower input shaft...not sure about shaft swap on the SCX.
#67
#69
I know John the owner of BMax very well and I can tell you that his drives fo live. The upper for one is much larger. He cryo treats the gears on the upper and lower along with the other special treatments to the innternals. I personally believe it is a good product and a viable option to a true plug and play bravo replacement. Plus I ve had them on two separate BT's so i have actually run his product.
