Any ideas for removing this stain?? >
Old 08-24-2011 | 07:59 PM
Ted G's Avatar
Leave it in the sun for about a week.
www.cbpba.com
Ted G is offline
Old 08-24-2011 | 08:09 PM
Maybe try Spray Nine, it works great.
AB From Windsor is offline
Old 08-24-2011 | 09:07 PM
Mineral Spirits.
Maybe try hairspray or lysol, I know it takes off permanent marker.
BIGSLOW is offline
Old 08-25-2011 | 12:10 AM
Sydwayz's Avatar
Forum Regulator
Run by Advance Auto; swing thru the rice-a-roni aisle, and stick a leather wrap on that bad boy.
Sydwayz is offline
Old 08-25-2011 | 01:04 AM
i would try wd40 or carb cleaner but use the carb cleaner lightly --simialar to lacquer thinner
kilrbusa is offline
Old 08-25-2011 | 05:50 AM
soak some bleach on a wash cloth. set it on the stain and leave it on the stain over night. the bleach will pull out the ink
Face It is offline
Old 08-25-2011 | 05:55 AM
BONDO10's Avatar
Thank you. I am now officially spitting coffee out of my nose.
BONDO10 is offline
Old 08-25-2011 | 06:53 AM
OldSchool's Avatar
LMFAO!!!!
OldSchool is offline
Old 08-25-2011 | 07:11 AM
augie58's Avatar
I actually painted the steering wheel on my 98 formula. The paint I used was Rustoleum vinyl paint. Worked great.
augie58 is offline
Old 08-25-2011 | 07:12 AM
Indy's Avatar
Member #154
After using all the aforementioned products, it will have dissolved the vinyl leaving you with the frame only and you're problem is solved!
Indy is offline
