-   -   Mando alt from db electrical?? (https://www.offshoreonly.com/forums/general-boating-discussion/262101-mando-alt-db-electrical.html)
scott.downey@cox 09-12-2011 12:37 AM
Give Gus at Ohio Generator a call, he built a couple 160 amp alternators for me.They worked great on the ZO44 Corvette Boat (330)-323-5742. Theyare the best in the business.
Mr Gadgets 09-12-2011 04:40 AM
Well stay away from the one wire alternators. They sense the voltage right at the alternator and not at the battery. Some take a few rpms to get started, some start at an idle. With fuel injection and I believe in your case, the three wire will be much better for you.
Call the guys at DB, they can probably help you out.
Or give Gus a call as Scott said. A one on one with a good alternator guy is well worth the effort.
Dick
290enticer 09-12-2011 05:44 PM
I had the alts tested today, one was good and the other was dead. That one alt is running everything, I ordered a replacement mando today for $86 bucks. 65amp hr. from db electrical
