drive questions on cig
Old 09-15-2011 | 09:58 AM
Default drive questions on cig
Ok my cig has sportmasters on bravos with ITS. I have heard that the sportmaters are slower than reg bravos. I have 34 pitch bravo ones. They are original drives and props. Boat hates any trim. if you bump the trim it runs into limiters hard. Runs very flat also. water breaks way before tstep. the same boat is next to me except hes had standard lowers. same motors props and everything. is boat runs completely diff. also 8 mph faster. my motors are mounted 1.5 inches lower in the boat but with the shorty my props are like over 2 inches higher than his. Whats the deal with the long skegs? I had heard they put these on the sv boats to slow them down. Any ideas?
SVL-WARLOCK is offline
Old 09-15-2011 | 10:04 AM
Drop on some standard lowers and see how it rides.
Back4More is offline
Old 09-15-2011 | 12:44 PM
what kind of cig and where are your prop shafts in relation to the bottom at level trim
GOFSTCAT is offline
Old 09-15-2011 | 02:24 PM
THEJOKER's Avatar
Yes get rid of the sportmasters.
THEJOKER is offline
Old 09-15-2011 | 02:25 PM
OL40SVX's Avatar
Rotation of props and power?
OL40SVX is offline
Old 09-15-2011 | 05:19 PM
until you get into the mid 80's the lower unit with the least sq inches dragging through the water will be faster. also the flat nose of a stock Bravo takes trim better than a cresent nose (On some boats). you may want to try stock lowers and see, the lower prop height will help the trim issues as well.
fastdonzi is offline
Old 09-15-2011 | 08:13 PM
THEJOKER's Avatar
I had an 02 TG w/575's. Put the sportmasters on and it was a dog.
THEJOKER is offline
Old 09-16-2011 | 09:31 AM
Quinlan's Avatar
Thats good to know. I have same boat and have been thinking bout trying some.
Quinlan is offline
Old 09-16-2011 | 01:52 PM
THEJOKER's Avatar
With ITS on XR 1.5 Bravos - 5 blade Herings we ran 93 mph. Weight was around 12,000 lbs w/ fuel.
THEJOKER is offline
Old 09-16-2011 | 09:30 PM
Tim G.'s Avatar
Performance Boat Center
Try a 32p B1... They act different than 34s. Worry about the top speed and RPM once you like how the boat acts...
I have never been a fan of the 34 B1.... Trust me.
Tim Gallagher
Performance Boat Center-FL
[email protected]
954-809-8739
Wright Performance, MTI, Cigarette, Sunsation
Tim G. is offline
