gauge help???
Old 10-04-2011 | 10:13 PM
Default gauge help???
hey guys im new here... i own a 98 scarab 22 and unfortunatly one of my gauges broke, needless to say its one of the odd ball 4-5/8 gauges.
all i can find are 3 3/8 or 5" gauges.. i found 2 different 4 5/8 gauges by gaffrig and teleflex but WOW $$$.
does anyone make a shortcut to fix this issue, say an over sized gauge bezel to utelize a 3 3/8 gauge in the 4 1/4" hole?
if not how about aftermarket scarab 22 dash??
thanks for the help.
matt1840 is offline
Old 10-05-2011 | 01:08 AM
What gauge and what brand???? It might be able to be repaired.
Why can't you just cut the hole bigger???
Griff is offline
Old 10-05-2011 | 02:11 AM
Dave M's Avatar
Veteran: Navy
Welcome to OSO.
How do you know the gauge is bad? More often than not, it's the sender or the wiring that's bad.
Dave M is offline
Old 10-05-2011 | 10:04 AM
the tach has been on the fritz, and honestly the previous owner has replaced other smaller gauges as they went out or broke, but obviously on a tight tight bugdget because their miss matched....
basically id like to replace them all and get a matching set to help accent other things i have done to the boat.
ive got two 4-5/8" gauges and five 2-5/16 gauges i belive..
teague and livorci are way way pricey just for the two individual 4-5/8" gauges they make, i just cant afford em
how about aftermarket oversized bezels?
ive got a 4-1/4" hole cutout for them both, anyone make a bezel with say a 3" id and a 5" od??
lemme know
matt1840 is offline
Old 10-05-2011 | 10:43 AM
teaguecustommarine's Avatar
Offshoreonly Advertiser
A 5" gauge is most likely a 4 5/8". They measure to the outside of the rim vs. the hole cut out.
I can guaranty that it will be cheaper to replace 1 gauge before replacing the entire dash to fit another size.
What is the make and the function of the gauge you need? Unfortunately the 4 5/8" gauges are either the Tach or the Speedo, which are the most expensive. Give us a call, we can work to match the same gauge that you are needing for a very reasonable price. We might even have 1 on the shelf that we will make a smoking deal for. -Eric
TEAGUE CUSTOM MARINE
661.295.7000
www.teaguecustommarine.com
teaguecustommarine is offline
Old 10-05-2011 | 11:39 AM
Look on ebay
Griff is offline
Old 10-05-2011 | 12:24 PM
These are the original faria gauges used in the 96-98 scarab 22s. The gauge face of the tach an speedo are 4-5/8" outside of the ring. The actual body and hole cutout for the gauge is 4-1/4".
I've got a 5" autometer tach that's a true 5" outside of ring, these side by side in my dash will hit eachothers rings being that the holes cut in dash are just to close for a 5" gauge to be used.. I need somethin with a true 4-5/8" outside ring diameter.
matt1840 is offline
Old 10-05-2011 | 02:03 PM
Only enlarge holes to the outside????
Griff is offline
Old 10-05-2011 | 05:24 PM
i thought of that as well, also took those measurements, and well my smaller gauges will be in conflisct...
im annoyed right now lol... and as far as i understand wellcraft no longer makes dash blanks for these boats.
matt1840 is offline
