labbed props....worth the money???
Registered User
The previous owner had the props labbed on my boat.
They run smooth and the boat is fast, BUT, I got a little to close to the left prop when putting the drain plugs in the boat, while on the trailer and the prop layed my arm open like a razor blade. Left quite a scar too. Also, when they have been labbed they are much easier to damage if you hit something and much harder to repair, sometimes not repairable. I don't think I would spend the money on it unless I was racing.
My 2 cents, worth what you paid for it!
Thankyou for all the input, the boat is wanting to cavitate while coming on plane and coming off of plane with drives down, if i play with trim and throttle, i can get it to go away, I have shortened the shower pick-ups (per brett) and noticed that my port pick-up in installed on the "wrong" side of the cavitation plate ( on the down stroke) of the prop. I will change this but wont have the boat out till next spring, im gonna winterize it this weekend. I have some small knicks in the props but overall they are in pretty decent shape. I didn't know that lab work involved making the blade thinner?? I boat in the ohio river, so there is alot of drift and debris that you do hit. I deffently don't want to weaken a blade by doing this, Maybe i can find someone that can just fill in the knicks and reshape the leading edge?? I am running mercruiser Bravo1 four (4) blade 24p
I am a lake boater & have always run labbed propellers. That being said, they have their place & that place is not on your boat in unfamiliar waters or on a river.
I have 4 sets of propellers & they all suit my needs. 4 sets of Bravo's, (2) labbed & (1) stock along with a labbed set of Maximus wheels.
I've owned probably 10 sets of labbed propellers & they all have lived very good lives, ever being broken by my supercharged horsepower.
290Enticer,
Have you tried using one of the Prop Calculator programs to gauge the efficiency of your current props. Props can make a huge difference (better or worse) but you need a baseline of your existing setup to know which way to go. Run your numbers on one of the free websites or download one of the free prop calculator apps for Iphone/Droids. Below is one of the freebie sites, you could also try BAM or Merc's websites too.
http://www.rbbi.com/folders/prop/propcalc.htm
http://go-fast.com/Prop_Slip_Calculator.htm
If your estimated slip numbers are single digits and the boat handling is decent you probably wouldn't see huge improvements with labbing or even different props. If there are handling traits you don't like or your slip numbers are really high then spending money on props can be money well spent and enjoyed.
Just my two cents worth, if you make changes please post the outcome we appreciate learning from others.
Thanks,
Rick
Thanks,
Rick
He does every prop i own. I did chunk one blade one time but hey...that is performance boating!!Skydog
