Cutting prop Dia?
Old 10-22-2011 | 06:26 AM
sean stinson's Avatar
The Illustrious One
Veteran: Navy
Originally Posted by Noise Pollution
Instead of labbibg or thinning the blades, what about cutting the diameter down? How muchwould you have to cut for 300 or 400 rpm? What effect would it have in the mid range?
PM your contact info and I will give you a call!!!!
Dying,....Is the day worth living for!!!!!!
sean stinson is offline
Old 10-22-2011 | 06:29 AM
The Illustrious One
Veteran: Navy
Slip is around 14%. Little scared of a five blade. 700#'s of torque through a bravo one.
If you go to a 5 blade it will improve your cruise significantly....BUT....you can't have a heavy hand if you catch my drift!!!!! In other words you can't have very many misses before you break something!!!!! So how much hardcore WFO boating do you do????
Old 10-22-2011 | 08:20 PM
I have a stock 26. I put a borrowed shorty on the boat. I first tried a the 26. I could turn it 5200-5300 rpm.It was like spining tries. Boat only ran 60.The 28 has a supper cruise in the mid range. Just need a fer more rpms.
Also both props measure 15" in Dia.
Noise Pollution is offline
Old 10-22-2011 | 08:25 PM
The Illustrious One
Veteran: Navy
Not 15.25"????
Old 10-22-2011 | 08:32 PM
Originally Posted by sean stinson
Not 15.25"????
No. its 15"
Old 10-22-2011 | 08:55 PM
No. its 15"
Yep. Why merc stamps them 15.25" beats me. Maybe Bblades can tell us this. As mentioned ealier, it's only the 32 and 34 that measures 15.25"
A.O. Razor is offline
