Looking for 400hp small block for cat >
Old 12-12-2011 | 08:36 PM
Originally Posted by Originalronza
It will be twins, will push it close to 120mph
What drives are you planning on using?
Maritime_Eng is offline
Old 12-12-2011 | 08:48 PM
Is anybody offering LS engines. In auto world are cheap and durable. Have really hurt the small block.
Cruz-N-Thunder is offline
Old 12-12-2011 | 09:08 PM
Originally Posted by mike tkach
wrong ,a pair of 400 hp anything will push a 30 ft cat not even close to 120
Sorry manufacturer said 400hp at prop pushes it 110, I misunderstood what they said. Thought that was pretty optimistic, but even with 496ho that is really good
Originalronza is offline
Old 12-12-2011 | 09:37 PM
what brand of boat are you talking about?maybe i need to buy one.
mike tkach is offline
Old 12-12-2011 | 09:53 PM
It ain't AO that's for sure!
Catmando is offline
Old 12-12-2011 | 10:06 PM
u got that right,my ao needs 950 to see 130,i want one of them cats that does 120 with 400 ps hp,then il put my engines in it and go 270
Old 12-12-2011 | 10:09 PM
hay cat,does that hemi in your 300 have 400 hp
Old 12-12-2011 | 10:17 PM
I'd bet 400hp outboards would get that boat to 110!!!!!! YEEEHAAA.
Darrell.
DMOORE is offline
Old 12-12-2011 | 10:28 PM
400 Hp in a small block is easy to do. A GM crate ZZ383 makes 425 HP at 5400 and 460 ft/lbs of torque. My 355 built in 1995 with off the shelf Dart iron heads and a Crane,
http://www.cranecams.com/product/car...detail&p=24208, made 424 hp and 445 ft lbs. By the way if you compare the specs that Crane cam appears to be the same as the one in the GM ZZ383. If I were to do it myself I would start with a larger motor (420-430 ci) Some better flowing heads, and I would most likely use that camshaft again but pair it with some 1.6 rockers. I bet that would make close to or slightly over 500 hp over 500 ft/lbs, and still be able to idle through all of the no wake zones with ease (mine idles all day at roughly 600 rpms). Of course this is if I were to stay with a conventional small block. My first choice would be to go LSX, but that is another debate.
fastestbowtie is offline
Old 12-12-2011 | 10:30 PM
Darrell.
Pair of these?
http://www.seven-marine.com/
