Looking for 400hp small block for cat >
Old 12-15-2011 | 12:26 PM
  #51
Originally Posted by Uncle Dave
Light - yup check that box.
Just as reliable- well know in 10 years
More efficient - it take X fuel to make X HP not sure they are any more efficient per HP than big blocks- check a maybe
Cheaper - I dont know for sure that its less money.
I think you'll find that turnkey small blocks marinized in the 5-600H range to be 20K +
Ralyar LSM-550
Mast 600
ILmor LS series
Pretty sure all of these crack 20K when delivered ready to run.
UD
Those motors are out of my price range .ive found 3. Good builders who can produce 600hp complete for 18k. Would love to go with mast if they were more competitive. Looking to build a custom predator, with a cool bussel making it over 33' loa, with tunnel extension, full windshield, surface drives. This boat will be as cool as Jim's skater and every bit as fast. With the 600's were hoping for mid 130s for speed,
Originalronza is offline
Old 12-15-2011 | 12:42 PM
  #52
I must say I am a little disappointed in the numbers that have been offered by LS builders on this forum. When a crate motor offered by GM is 430 hp configured with a restrictive intake/air cleaner, and stock cast iron manifolds with low flow cats etc. it seems a little odd when a custom builder totes marinized versions of the same motors in the same or close to the same HP rating. Even GM offers it with just a cam change at 480 hp, and everyone in the automotive arena knows that with just a cold air intake high flow cats, some minor exhaust work, and a more aggresive tune these are well over 450 hp at the flywheel. I would expect a marine application for these motors (provided they do not have to live up to some crazy emission standards) to start at 500 HP (for the 6.2) and go up from there.
fastestbowtie is offline
Old 12-15-2011 | 01:14 PM
  #53
Awesome. That was what I figured. I dont know if the speed that you are hoping for will come to pass, but I think it is certainly possible considering the Stihl Skater ran 130 or better with a set of 525's.
Are you doing the C306? with the full windshield? That would be sick.
Good luck with it.
Philm is offline
Old 12-15-2011 | 02:04 PM
  #54
Stormrider's Avatar
JC Performance Engines
Just call JC Performance.
He is on LI too.
He can build a 475hp 383 no problem.
Stainless Marine manifolds would work well with it and are costs effective too.
Stormrider is offline
Old 12-15-2011 | 03:43 PM
  #55
Agreed- the numbers arent working for me.
I love all the tech but in terms of HP per dollar its not a deal.
Ive already built 500HP SBC's with 10 year lifespans and good dosckside manners for under 10K- the whole thing seems way out of whack to me.
I know they aren't exactly the same, but the net net of the difference is really only 2 things.
1. I have an Iron blocks if I spend 4K per I get aluminum but net net I dont buy the stock block so its a 3K delta.
2. Injection- they have that but other then not needing ro rejet at altitude changes, Im unsure thats worth the price.
Ive had to mess with my Carb exactly twice in a decade.
Ill save the 10K and spend 5 of it on gas booze and loose women, and the other 5K one of my other 20 toys (like tires for the motorhome)
UD
Uncle Dave is offline
Old 12-15-2011 | 05:44 PM
  #56
Good luck with it.
Yep
Old 12-15-2011 | 05:51 PM
  #57
offshoredrillin's Avatar
check out these guys, they can marinize it for you...ask for Chad the owner...
http://www.golenengineservice.com/
offshoredrillin is offline
Old 12-15-2011 | 06:26 PM
  #58
blume's Avatar
Default 30' Skater
IDK if I believe all this about big blocks not being good for a 30'. In my opinion this is the hottest 30' on the water. It has big block power and Arneson drives.
Attached Thumbnails Looking for 400hp small block for cat-dsc01463.jpg   Looking for 400hp small block for cat-dsc01462.jpg   Looking for 400hp small block for cat-dsc01466.jpg
Looking for 400hp small block for cat-dsc01455.jpg   Looking for 400hp small block for cat-dsc01458.jpg
blume is offline
Old 12-15-2011 | 06:29 PM
  #59
Good luck with it.
do you guys have any idea what it takes to get a 388 skater to run over 130 ? really stock 525's, you forgot to add in the altered PCMs, #6s with $10K HERRRING props and in kilo setup.
same for 390hp, 105 mph cat. i'll give that that boat might have ran 105 at some point maybe with a 20 mph tailwind, but as for an everyday setup that thing will have no acceleration. hopefully you never meet up with a 28 skater with 300x's. it would be embarrassing to get whipped by a outboard cat.
plus, your looking at HP when you should be looking a torque curves.
skaterdave is offline
Old 12-15-2011 | 06:42 PM
  #60
Dave the predator had very good acceleration with the small blocks on bravo props, and ran that speed going into the wind. We are going with arnesons which should push it 5-8 mph faster than the imcos, and it eventually went 110 after it got dialed in. And the boat with twin 300x's went 118 mph
