700hp Fountain 27
Old 12-25-2011 | 10:54 PM
  #51
my dyno sheet is on page 4. i will be trying a 1 inch spacer in the drive in the spring. mabye i should b faster idk? i have a bravo x upper -1 imco sc lower. i think i was held back by the props. it did run 85 with a 28" bravo around 5700 making peak hp at 6300. i feel with some fine tuning it should run high 80's to 90. lets keep torque in consderation too when talking about hp. also its not a stepped hull.
+1 for a pontoon boat that can run 100. thats just nuts!
ita1iansta11ion1 is offline
Old 12-26-2011 | 12:15 AM
  #52
Old 12-26-2011 | 12:24 AM
  #53
Old 12-26-2011 | 12:32 AM
  #54
Old 12-26-2011 | 12:35 AM
  #55
Old 12-26-2011 | 12:44 AM
  #56
Old 12-26-2011 | 02:41 AM
  #57
articfriends's Avatar
Originally Posted by ROTAX454
Where is Smitty when you need him. Here is the crane spec sheet on your cam.
http://www.cranecams.com/product/car...detail&p=24223
700HP you say. Hmmmm. Really curious to see those dyno sheets. Be sure to include all of the dyno data. Fuel and air numbers count too.
No criticisms or nonsense. Just some straight honest questions. Afterall, your the one touting the 700 number.
IF you made a REAL 700 hp from a 510 ci with a Crane 651 N/A I would be real surprised. Fountains typically run pretty fast though without a ton of hp. I see flat tops , canfield 310's and a crane 651=600 hp would be my guess if I didn't have your dyno sheet to look at, if you were closer I would race you with my Baja 272, its not as sporty as a fountain but it will run 100 mph, Smitty
articfriends is offline
Old 12-26-2011 | 07:31 AM
  #58
I think the dyno sheets show 699.2 @6278rpm... Crank and corrected but that validates a 700hp claim as far as I'm concerned.
machloosy is offline
Old 12-26-2011 | 08:41 AM
  #59
THANK YOU!
smitty, how are u going to compare a 1000+hp boat to one that allegedly only has 600 hp? in reality 700hp. call bandit performance marine, 732-477-7400 and ask for danny, the engine builder. theyre a great bunch of guys very knowledgeable and im sure he will gladly have a 20 min discussion with you about how my 510 motor he built made 700 hp.
Old 12-26-2011 | 09:21 AM
  #60
use good parts, u get good hp. research aed performance carbs out of virginia. i have a 1050 dominator redone by them to exactly match my motor and it gave almost a 25 hp gain over a stock 1050. profiler jr intake manifold, canfield's, 2.25int scorpions 1.90exh ferrera, ferrea springs and retainers, 1.7 rockers, (crane gold in pictures but i changed those out for scorpion offshore endurance rockers), 10.0-1 comp, bandits custom piston with teflon coated skirts, gas ports and total seal rings, scat rods, stock forged crank.
