moisture control in boathouse >
Old 12-25-2011 | 05:00 PM
Default moisture control in boathouse
We have a fully inclosed, insulated boathouse with overhead doors and vinyl from bottem of doors to waterline. Due to cost, I do not want to heat through the winter. I am already finding mold growing inside the dock and everything is wet. So do I?
Place a dehumidifier? Dock is approx 24 x 30 - do I oversize considering I have two open slips? Am I fighting a losing battle with two open boat slips and using a dehumidifier?
Or do I Just open the dock and let it air flow? I think this will work or help but i do have security concerns.
Suggestion?
Thanks, chad
RebarBox is offline
Old 12-26-2011 | 11:54 AM
GO4BROKE's Avatar
I would try to add some forced ventilation. Then you can keep it locked up and still air it out. I don't think the dehumidifier will ever win the battle.
[img][/img]
GO4BROKE is offline
Old 12-26-2011 | 12:50 PM
the dehumidifier will never win the battle ,better open up the ridge cap and a few vents so it can breath ... look around on here and check out Bill Ps
ROCK ON !!!!!!!!!!!!!!!!!!!!!
ITS A SKATER NATION !!!!!!!!!!!!!!!!!!!!!!!!!!!!!
HAPPY HOLIDAYZ !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!:bi gbird:
Old 12-26-2011 | 05:07 PM
FunHome's Avatar
Get a fan to circulate the air and leave a light on..
Mold grows best in damp, stagnate, dark places...
FunHome is offline
Old 12-26-2011 | 07:02 PM
hp500efi's Avatar
Member #9
exactly, keep a door open and if possible, a forced exhaust fan to keep the air moving with new fresh air.
Member of the Liquid Jungle
hp500efi is offline
Old 12-26-2011 | 07:12 PM
The bottom of the house is open to water? Unless you can stop the source of the humidity you can't control it. You need to circulate air outside the boat house thru the boat house. This will drop the humidity in the house as long as the outside air is less humid that the inside air.
looseconnection is offline
Old 12-26-2011 | 07:18 PM
WINNER WINNER CHICKEN DINNER !!!!!!!!!!!!!!!!
why not put the hot tub in the Kitchen
HAPPY HOLIDAYZ !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !
Old 12-26-2011 | 07:59 PM
Try removing the vinyl you have on bottom of door to water line and vent at opposite end of boat house so air can move. Maybe enough to kept humidity down
Clustergear is offline
Old 12-26-2011 | 08:09 PM
A couple ceiling fans would probably do the trick. Just need to circulate the air.
07DominatorSS is offline
Old 12-26-2011 | 08:39 PM
YES MOLD LIKES THE DARK
schnydo is offline
