Prop help
We have a 2012 250 verado on a 25' tritoon southbay. Runs great with a 19 pitch merc prop. Turnd 56 hundred rpms. at 51 mph. Looking for a 4 blade prop. It should turn what rpms at wot?? I was thinking about b blades? Has anyone tryed them on a tritoon? The boat has strakes. Looking for more midrange. Thanks for Your help. Artie
If you are spinning 5600 rpms, you are quite over propped. Your motor is supposed to spin 5800-6400 rpms. For a 4 blade, I would try a 17" Revolution4. With your slip of about 7%-8% at the moment, and partially depending on which Merc prop you've got now, it should put you around 6000-6100. That should work quite well for mid range efficiency. A 17" Mirage+ could also be a good choice, even though it's a 3 blade. Which Merc prop are you currently running?
A.O.Razor Thank you so much. Thats the same prop We were looking at. I've never been on this boat it's a friends boat. I don't know what merc prop on the boat now. I tried calling bblades today. Will try again monday. Thanks Artie
You're welcome. Is the 51 mph gps or pitot speed btw?
