Vessel Documented??
Old 02-16-2012 | 02:06 AM
Default Vessel Documented??
I finally got my papers showing that my formula is documented through the US Coast Guard, does anyone else have there's documented and if so what all do I need to have done. Do I still need to get it registered or is the document enough to run. I still have to rename it and put the new port of call on it just wondering what else.
s022mag is offline
Old 02-16-2012 | 05:02 AM
That is the only registration that you need. You must put the USCG registration number on the hull in a manner it cannot be removed(easily) This is usually done in the engine compartment where it is visible on inspection. I used stick on letters and covered them with 3m clear bra. You need to keep your registration paper on the boat for inspection. There are rules for sizing of lettering for name and port of call. Also required to have a "no oil discharge" plackard on the boat somewhere.
You also maybe responsible for State and Local taxes at place of mooring. I pay Kentucky property tax. Some don't need to pay, some don't pay, find out in OH.
SkiDoc is offline
Old 02-16-2012 | 05:52 AM
yschmidt's Avatar
In Oh you still have to have the state registration also, but you are not required to have a state issued number on the hull. If it is a new purchase contact the tax guy, so he doesn't have to find you. He made it very clear if they have to find you it won't be good.
If you are paying the cost to have the documentation changed you may want to weigh out the costs of just doing a state registration and not document the boat.
yschmidt is offline
Old 02-16-2012 | 06:02 AM
hp500efi's Avatar
Member #9
If your State also requires registration (like WI), I did what you did (documented boat W/O applying the state stickers & numbers on the hull) and I continually got hassled by the PoPo everytime on the water. In the mind of the Police/DNR etc, they assume that the boat is not registered unless they see visual registration stickers and hull numbers.
Even though I was legal with the documentation, I got tired of the hassle and proving that I was legal. I finally decided not to renew the fed documentation and then applied the State registration stickers and hull numbers. Problem solved.
There are a number of states that require registration regardless of it being fed documented or not.
Member of the Liquid Jungle
hp500efi is offline
Old 02-16-2012 | 06:38 AM
Quinlan's Avatar
Even though I was legal with the documentation, I got tired of the hassle and proving that I was legal. I QUOTE]
Exactly Hassle Not that any of us Drink while boating!
Quinlan is offline
Old 02-16-2012 | 06:48 AM
LAriverratt's Avatar
i was stopped here locally and told that if i put the sticker on the bow where it was visible that's all they need to see....didn't need to put the state reg #'s on the boat just keep the state paperwork with the USCG doc.
LAriverratt is offline
Old 02-16-2012 | 06:54 AM
Payton's Avatar
Charter Member #927
That is how Indiana works also. The state gets their property tax $$ When you buy a sticker and everyone is happy. No Numbers. I've been checked once in 6 years. I really think they wanted a closer look at the girls onboard.
Payton is offline
Old 02-16-2012 | 07:38 AM
Downtown42's Avatar
Exclamation
In WI, a documented boat is required to be state registered. No state numbers are said to be displayed
on the vessel, however your square state registration stickers need to be displayed on each side of the vessel name on the transom.
pg 5 WI BOAT REGULATIONS
http://dnr.wi.gov/org/es/enforcement...oatingregs.pdf
Documented Vessels:
Larger recreational vessels owned by U.S. Citizens may (at the option
of the owner) be documented by the U.S. Coast Guard. Call the USCG
at 1-800-799-8362 for more information. Documented vessels must
also be registered in Wisconsin.
• The registration decals must be displayed on either side of the
vessel’s name on the transom. The state assigned registration
number is not to be displayed
Downtown42 is offline
Old 02-16-2012 | 08:02 AM
I bought the boat last year and the guy I bought it off of lived in the state of Ohio and he had the boat documented because he claimed he didn't have to pay sales tax and that was one of the perks of documenting the boat.
I was stll planning on having the registered in Ohio just not display the OH numbers. The ODNR site says that if I Want to register the boat that I either need a title or documentation papers which I just received about a month ago.
s022mag is offline
Old 02-16-2012 | 08:05 AM
What was your time frame from submition of papers to boat being uscg doc ?
scarab63 is offline
