Noli
Make sure you make it clear that this boat being built is your personal boat. Also that you are not employed by Predator etc.. Otherwise a great thread ( Like the last one) may get poofed by the moderators:) |
That's correct. I am not an employee of Predator, nor am I a broker of Predator Powerboats. I respect Arnaldo (owner) a lot and am a big fan of his products...all of them... Did I mention a 35 foot CC cat in the works? power options: I/O and Outbds We can custom build to customer's specification. |
Originally Posted by Crazy Dayz Donzi
(Post 3622273)
now i see why all the questions about the skater layup..:party-smiley-004: I don't believe there is a alternative to a skater!!
Two completely different boats. |
Any plans to build the wider version or only if someone places an order?? Looking forward to seeing this build come along.
What's the width on the wider version.
Originally Posted by noli
(Post 3622275)
This one will be built a little lighter than the previous customer's boat. Lighter because it will be used in Poker Runs. Will be a canopy deck. Again, at this time the factory has no dealerships only because we learned a lot from the Jim Darr incidents (which spanned a total of almost 7 years) But we need all the help we can get. Fast Fun 2 (J) is an incredible guy. Straight up shooter. And others, you all know who you are. (P) down in FL. These are the folks who collectively has helped us along. I will be trailering the hull a lot, trying to go to as many Poker Runs as possible. Will be a joint effort between the factory and me. Which is why we opted for the 8'6" beam. We can still deliver the wide body models for those interested. |
Noli-
Are you planning on rigging this boat with 300xs's? What is the planned finish date of this build? Thanks Don |
I am not yet decided on the power
I like the power and RPM band of the 300X I also like the fuel savings from 300XS I also would like to look into Wilson Custom for my lower gear cases would you know where I can get 300XS cheap? |
(Post 3623110)
Are you familiar with this boat? have you run them before?
| All times are GMT -5. The time now is 01:52 AM. |
