-   -   scarab 1 MPH (https://www.offshoreonly.com/forums/general-boating-discussion/271727-scarab-1-mph.html)
Toy Boy 03-01-2012 12:05 PM
scarab 1 MPH
hey everyone im curious what mph can i expect from my boat i just got 85 scarab 1 with 265hp small block and a alpha 1 outdrive ? also ive been told that this boat will burn about a galion of gas per min at wide open throttle is this a accurate assumtion ? im new to the boat sene and i appreciate all the advice and help u give
Thanks Matt
Secret Formula 03-01-2012 01:28 PM
Maybe low 50's and probably 1/2 gal per minute.
Griff 03-02-2012 12:18 AM
Originally Posted by secret formula (Post 3630945)
maybe low 50's and probably 1/2 gal per minute.
x 2
Powerquest_Baby!! 03-02-2012 12:54 AM
Pull the throttle back to 3000-3200 rpm if you want to save gas....it will use half what you do at wot.
spectras only 03-02-2012 01:13 AM
According to Boating , Richard Tiel did test the 1985 Scarab 1 with 260HP Cobra 260, 14 x 21 1/2 pitch 3 blade SST, 1.41dr .
Here are the specs.
Fuel cap is 60 gal.Weight 3350. Test was done with 2 persons, 7/8 fuel, moderate gear onboard.
2000rpm=10.2mph,3.7gph,2.76mpg
2500rpm=27.7mph,5.5gph,5.04mph > longest range = 235 miles
3000rpm= 36mph, 7.5 gph, 4.80mpg
4000rpm=50mph,16.2gph,3.79mpg
4350rpm=54.1mph,20.5gph,2.64mpg shortest range=124 miles
Toy Boy 03-06-2012 09:53 AM
scarab 1 mph
thanks for the info guys i appreciate it
