Quiz...I think this could be fun >
Old 03-22-2012 | 04:39 PM
Nice Pair's Avatar
I would think that Captain Kirk knows about the x-dimension, If not Spock knows for sure.
Nice Pair is offline
Old 03-22-2012 | 05:49 PM
My Ex Wife
akaboatman is offline
Old 03-22-2012 | 07:36 PM
Originally Posted by akaboatman
My Ex Wife
Was she BIG?? (Dimension Wise?) j/k Lol
fastdonzi is offline
Old 03-22-2012 | 07:47 PM
It is really from early boat building days when they measured the transom for the drive cutout. They would mark a line straight across the chine (looking at the transom) and measure up from there (Not from the running surface like they do today) Then measure laterally out from center (after finding the transom center) for twin engine boats, and just using the center for singles, They would mark the spot to drill with an "X" hence the X-Dimension....No Sh*t
Old 03-22-2012 | 09:10 PM
the deep's Avatar
Fast Singles Club
Veteran: National Guard
[QUOTE=fastdonzi;3647180]It is really from early boat building days when they measured the transom for the drive cutout. They would mark a line straight across the chine (looking at the transom) and measure up from there (Not from the running surface like they do today) Then measure laterally out from center (after finding the transom center) for twin engine boats, and just using the center for singles, They would mark the spot to drill with an "X" hence the X-Dimension....No Sh*t [/QUOTE
I thought it was the X you draw on the bottom of the boat when you found a good fishin hole ...... so you can find it again .........:fi sh:
the deep is offline
Old 03-23-2012 | 02:02 AM
Originally Posted by RT930turbo
Distance from the Crankshaft center-line to the bottom of the boat
Correct
Originally Posted by POWERPLAY J
Propshaft centerline.
Incorrect.
Griff is offline
Old 03-23-2012 | 05:31 AM
Biggus's Avatar
I thought it was the X you draw on the bottom of the boat when you found a good fishin hole ...... so you can find it again .........:fi sh:[/QUOTE]
That's it!
Biggus is offline
Old 03-23-2012 | 06:26 AM
it is eally all about the propshaft centerline to keel dimension. BUT, you arrive at it by putting engine in it at a certain height (x-dim) so that with your drive length your prop is where you want it to be. assuming you can still close the engine hatch.
dereknkathy is offline
Old 03-23-2012 | 06:28 AM
yup.
A.O. Razor is offline
Old 03-23-2012 | 06:37 AM
Originally Posted by Griff
Correct
Incorrect.
Crankshaft of the engine?
POWERPLAY J is offline
