Imco Thumper power?
Old 03-24-2012 | 09:51 AM
Default Imco Thumper power?
Imco Thumper power? are they any good Ive never heard of them, what are they worth? I found a set never used new in box, was thinking about them for my 502
thanks
88242LS is offline
Old 03-24-2012 | 04:47 PM
masi242's Avatar
Couldn`t hurt maybe a little more sound and less money in your pocket
masi242 is offline
Old 03-25-2012 | 09:48 AM
IMCO's "Thumper" series exhaust manifolds are very similar to their upgrade "Power Flows". The "Thumpers" are primarily meant for replacement of stock cast iron manifolds at a more affordable price point. If you're 502 is basically stock, the "Thumper" series would be the way to good and you will see some modest performance/power improvement over stock cast iron manifolds.
twocents is offline
Old 03-25-2012 | 09:54 AM
thanks guys, however they only come with standard risers, and on the web site they don't offer a alt, not sure if i can buy a set for the powerflow if they bolt right up, I would think they do. but unsure.
88242LS is offline
Old 03-25-2012 | 11:42 AM
Correct about them being a replacements piece with a a bit more flow.
IF your old iron manifolds are leaking or bad, youll pick up some ponies and lose some weight bolting these on.
The power flows are a notch up- and have larger inner diameter runners and move more volume, power flows are a great high perf manifold for all but the wildest configurations.
UD
Uncle Dave is offline
Old 03-25-2012 | 12:56 PM
Expensive Date's Avatar
I have them, don't expect any more HP but they are lighter and cheaper than cast iron. I really noticed a difference in how my boat comes on plane and rides with less weight on the rear.
Expensive Date is offline
Old 03-25-2012 | 06:09 PM
Can Powerflows be a direct replacement for merc-gils
schnydo is offline
Old 03-26-2012 | 01:49 PM
thanks
is your power steering pump up by the valve cover on your motor????
reason i ask is i put Imco power flows on mine last year and the 90 degree hard line that comes out of the back of the pump hit the manifold.... after doing some research i see that they make a bracket to relocate the PS pump and alternator to fix this issue ($150ish)...... would have been nice to know before every thing was installed that this might be needed....
anyway by the time i bought that relocate bracket, and then bought the brackets to mount my thunderbolt module and shift plate assembly on the other side i ended up with about and extra $200 in parts i wasnt expecting.
gsxr1216 is offline
Old 03-26-2012 | 02:39 PM
hmm not sure until the boat gets home
88242LS is offline
