Who can Modify dry tail pipes >
Old 03-29-2012 | 06:49 PM
LOL....I thought you wanted a bung at the 10 degree joint....I was about to draw up a cross section to show you how that doesn't work...lol. Now I understand you want exhast temp bungs installed. That's a super easy job for any shop with a tig welder. They fab custom exhaust every day. They just might not have stainless rod for their tig welder. Worst case you'll have to stop by a welding supply company and pick some up. I could do it all for you but there shouldn't be any need for you to ship them anywhere...there are plenty of chassis shops around Cinci.
These guys do custom turbo exhausts so they probably have everything needed:
http://www.paulsautomotiveengineering.com
Hellbent is offline
Old 03-29-2012 | 07:02 PM
Sick Stinger's Avatar
Brotherhood #1
HellBent yup easy as pie I just ordered a new tig and plasma cutter cant wait to break it in
Sick Stinger is offline
Old 03-29-2012 | 07:40 PM
teaguecustommarine's Avatar
Offshoreonly Advertiser
Default Teague Custom Marine- 661.295.7000
Are you just wanting to change the outlet of the pipes, not change angles? If you just need to convert to or from dry pipes we can easily help you out with that! Shipping from Stelings to us will not be bad and we will ship them directly back to you. We currently have about 6 boats/tail pipe jobs at our shop from all around the country, our welders are the best! Give us a call! -Eric
TEAGUE CUSTOM MARINE
661.295.7000
www.teaguecustommarine.com
teaguecustommarine is offline
Old 03-29-2012 | 07:54 PM
You'll kick yourself for not buying a plasma sooner...lol. As your cutting your first piece you'll have flashbacks of every band saw blade you ever broke or the countless hours spent grinding out small areas or smoothing out torch cuts. lol
Hellbent is offline
Old 03-29-2012 | 09:08 PM
Default fixx
+1,,,if your not careful it will cut your fingers off too!!1
FIXX is offline
Old 03-29-2012 | 09:49 PM
Brotherhood #1
I have a small one but just jumped to a 80 amp
Old 03-29-2012 | 10:29 PM
Is the old one for sale?
pstorti is offline
Old 03-30-2012 | 04:43 AM
KAAMA's Avatar
Originally Posted by JIMKID Motorsports
There is a shop in Ohio that does Hardin marines tail pipes call jefe at Hardin in florida
Is this shop you're speaking of in Ohio in or near the city of Concord? I used to know of a shop somewhere around Concord, Ohio and a guy named "Bob" who was in charge, and was very talentend with stainless steel for marine exhausts---pipe bends, angles and welds, etc., and had done a couple of mods for me years ago, but I have since lost track.
KAAMA is offline
Old 03-30-2012 | 05:52 AM
Thanks Everyone.....Here are some pic's. The first pic shows the 10 deg angle needed also need length added to them. The original ones are straight.
Attached Thumbnails Who can Modify dry tail pipes-2012-01-07_17-31-29_373.jpg   Who can Modify dry tail pipes-2012-01-07_17-30-55_429.jpg
Face It is offline
Old 03-30-2012 | 09:07 AM
bcfountain's Avatar
Registered User
Originally Posted by pstorti
i'm sure stainless marine here in miami can do it, but any decent machine shop should also be able to do it.
good luck on that.
bcfountain is offline
