-   -   Normal to constantly run tabs unevenly? (https://www.offshoreonly.com/forums/general-boating-discussion/273811-normal-constantly-run-tabs-unevenly.html)
cmkworm 04-05-2012 02:51 AM
It definitely sprays water on the port side with the tab so I know its working. What is a LH prop?
FasterFaster 04-05-2012 09:34 AM
Left hand rotation (vs right hand). If it's prop torque, changing rotation should shift the hull rotation to the other side. Maybe you can borrow a LH prop from a buddy for a quick test. Of course the prop shaft needs to rotate opposite what you have now. You can run a Bravo drive shifted into reverse, but just long enough for the test.
NWPC 04-05-2012 10:00 AM
My 24 Warlock had the same problem. LH Prop cleaned it up and gained me a few MPH. If you are running a bravo outdrive, just swap the cables on your shift control.
Too Stroked 04-05-2012 10:20 AM
Somewhat normal on a single engine hull. In fact the narrower the hull, the more likely one is to have the problem. Sometimes shifting weight around from side to side will help. As others have mentioned, switching to a LH rotation prop will also generally help. (All 27’ Fountains came from the factory with LH props for this reason.)
Another lesser known fix is to engineer the condition out of the hull by making the bottom design ever so slightly different from one side to the other. (Asymmetrical) I’ll leave it to tx2, Brownie or someone much more qualified to detail this one, but it is done on occasion.
cmkworm 04-05-2012 12:38 PM
I guess I will keep an eye on it and if it does it many more times I will be ordering a new prop. I don't know anyone who has one. So all I will need to do is get a LH prop and switch the drive cables on the shifter for the Bravo 1?
Dave M 04-05-2012 12:43 PM
I have the same issue. I try to compensate by placing heavier passengers and gear to the star side. I'm going to try a LH prop as soon as I can get my hands on one.
onesickpantera 04-05-2012 01:56 PM
Same here. Fat dudes behind me, skinny chicks to port! :D
I never understood the LH prop. Wouldn't that just roll the boat to other side?
Dave M 04-05-2012 02:05 PM
Not sure. But most most of the Y2K's built in the last few yrs. are running LH.
My 24 leaned until I got up on plane and trimmed it out. Then it would roll right over.
1989mach1 04-05-2012 02:23 PM
lol it took 17 comments to get to the idea that mabe u just need to invite smaller chicks out on your boat..... thats grate. that was my first thought....:evilb:
RickSE 04-05-2012 02:34 PM
Another item that I don't think has been mentioned is that the torque steer should diminish as you trim up & speed up. Mine will torque steer up to about 45-50-mph. Once I'm trimmed up and past 60-mph it's pretty much gone for good.
