Running Hot
Old 04-29-2012 | 02:34 PM
Default fixx
Originally Posted by pacalim1965@yaho
Ok thanks, I was hoping it would be something fairly simple. I will pull freeze plugs and thermo and start sorting it out. Thanks for all your help.
if you deside to pull the engine remove the flywheel,remove the fron and rear freeze plugs and stick a hose in their and leave it run,,this will flusr all the sand out..
FIXX is offline
Old 04-29-2012 | 04:30 PM
Today i pulled the thermostat housing and reverse back washed through housing. I was surprised to see NO thermostat. Is that normal? The housing says Pro Charger on it.
pacalim1965@yaho is offline
Old 04-29-2012 | 07:26 PM
Lots of SC'd engines do not run tstats.
Griff is offline
