Starting Engine with no Water??? >
Old 05-24-2012, 02:44 PM
Default Starting Engine with no Water???
Can you start your engine in your driveway with out water hooked up , and if so how long can you let it run before damage occurs?
TC G is offline
Old 05-24-2012, 02:46 PM
Can you? Yes
Should you? No
Crossett is offline
IMO, I wouldn't even attempt that!!!
CigaretteSam is offline
Old 05-24-2012, 02:48 PM
If you disconnect the sea water pump belt it will be fine to run it for a minute or so. I've done this when working inside just to test quickly. Remember with no water it will get hot fairly quickly, and your temp gauge will not function so keep run time short.
RT930turbo is offline
Old 05-24-2012, 03:02 PM
Sea water pump belt = fuel pump= no start
olllotj is offline
Old 05-24-2012, 03:11 PM
Glad I asked. I'm not doing it period!
TC G is offline
Old 05-24-2012, 03:12 PM
The raw water pup impeller and plastic housing will be damaged without a water supply. Appx. $95-$110 replacement parts cost and 2 hours work replacing.
ed
Interceptor is online now
Old 05-24-2012, 03:22 PM
Unless you have engine mounted pumps, or electric pumps
Old 05-24-2012, 09:38 PM
good thinkin......
1989mach1 is offline
Old 05-24-2012, 09:47 PM
Default fixx
or until the float bowls run out of fuel..
FIXX is offline
