Water scum
Old 06-18-2012 | 09:57 AM
Originally Posted by machloosy
Ron,
Sat in the Seneca River May-Sept. I'm going to paint it on as thick as I can handle tonight and then go to dinner and see the results after. I'll wash the trailer off before I leave. If this stuff causes issues on the trailer, how will the outdrive handle it? Obviously same crud covers both the outdrive and the prop. The stainless prop literally feels like its been painted with grit...
The prop will clean itself trust me.
I put the stuff on everything, the painted drive will handle it as well, just watch around the anoides.
If you plan on buffing the boat after just hit the crud with a deck brush before rinse
4bus is offline
Old 06-18-2012 | 10:02 AM
Try FSR they sell it at westmarine works great
riverboater is offline
Old 06-18-2012 | 10:06 AM
Lemon Juice
Try it, you won't be disapointed
Dd24skater is offline
Old 06-18-2012 | 10:58 AM
Get Mary Kate On and Off. Put in pump sprayer. Wear goggles and mask. Wet down trailer and concrete. NOT BOAT. Spray bottom. Let soak. Work with NEW 6 inch plastic putty knife. GO easy, the crust will break up. Repeat after boat dries.
That crust laughs at Slimey grimey, pro one and everything else.
Trust me, I've actually done this & used most products. On & Off is the real deal. Muratic acid in close second but much harder on you and trailer and concrete.
DLEWIS1340 is offline
Old 06-18-2012 | 11:33 AM
This thing called work, keeps stopping my progress. I'm armed with a spray bottle, gloves, and a putty knife. 50:50 water:acid mix. Have a wire wheel and a drill to handle the prop!
I'll post up before/after pictures later.
machloosy is offline
Old 06-18-2012 | 03:45 PM
fabin61's Avatar
Go with Slimy Grimy... one full 16oz jar with HOT 3gal of water... if it doens't come off with that... wet sand with 1500 sand paper and than get a buffer same one everyone talks about on here and get a product called "Diamond Cut"
For the drives, just spray on muriatic acid and than pressure wash the drives and if necessary acid and pressure wash again.
If you have any chrome parts. Mother's Mag and aluminum polish and you will be the envy of all.
fabin61 is offline
Old 06-18-2012 | 04:15 PM
Mothers chrome/metal polish is gooooood stuff. Always had good luck, but need to cut through the crud on the prop to get too the metal too polish it. Should be able to get to this stuff in the next 2-3hrs!
Old 06-18-2012 | 07:42 PM
Default scum
by the on@off get a sprayer off of an old bottle of whatever put the sprayer right on the on@off bottle spray on and let sit but not to long you should be able to see the stuff going to work right away. Make sure the trailer and the bunks are wet because it will raise hell with a galvanized trailer. I do this procedure after every time i take the boat out. I get the Delaware River Tea Stain on the boat after every ride. The whole procedure takes about ten minutes. Also make sure you wear safety glasses or goggles. Do not get on the down wind side of this stuff because it will take you're breath away. It will also tear up concrete so if this comes into play make sure the concrete is wet. Rinse the sprayer out if you can because if you don't it is not going to work the next time you try it. Hope this helps.
jackieboy is offline
Old 06-18-2012 | 07:54 PM
Muratic Acid 50:50 with water... Holy CHIT!
Old 06-18-2012 | 08:03 PM
Yeah be careful with that stuff. We had a whole gallon of muratic that id dilute down to shoot on drill core to see if it fizzed or not (limestone). When id cut it down, the gallon jug would smoke when i opened it!
Shag555 is offline
