-   -   define "cruise speed" (https://www.offshoreonly.com/forums/general-boating-discussion/279119-define-cruise-speed.html)
PBR1 06-21-2012 05:11 PM
Originally Posted by fastdonzi (Post 3714517)
Cruise Speed is an RPM where your Not hurting the motor by running a Long distance at that speed/RPM. Usually about 3500 rpm, anyone who has a cruise rpm much higher than that doesn't grasp the idea. You Can gear & Prop your boat to be fast at cruise rpm, but acceleration and Top speed will suffer.
I agree that was very well said. However, most people will have different viewpoints and perspectives on this matter anyways.
Smarty 06-21-2012 05:12 PM
Originally Posted by LaVita (Post 3714533)
I've thought cruise speed to be 2700-3500 rpm
I also agree with you....
for Big Blocks, now for the 60 hp Johnson o/b on the back on my 15' Boston Whaler, that is another story
pstorti 06-21-2012 05:21 PM
28 Daytona twin 496 mags
top speed 90 @ 4900 rpm
Cruise 70 @ 4000 rpm
37 Spectre twin Yanmar diesels
top speed 55 @ 3800 rpm
cruise 38 @ 2900 rpm
Fast cruise 45 @ 3300 rpm
The eliminator had to be going over 50 to ride well, no tunnel spray ect, and fuel economy was the same from 40 to 70 so usual speed was 70.
the spectre i usually run around 38 upper 40's if i am in a hurry, I can run those diesels forever at 3400 rpm, but economy is better around 38. I know it's dead slow compared to a go fast but different kind of boat, although it does ride better as you speed up!
KCHOTBOAT 06-21-2012 06:03 PM
Originally Posted by TexomaPowerboater (Post 3714792)
415hp / 12 = 34.58 gallons per hour X 2 = 69.16 gallons per hour twin 502's. Looks reasonable, but their carbed motors not mpi.
We did agree you cover my fuel bill for the first month of owning the boat. I am sure we will go throw a few gallons the first weekend out at LOTO. See you tomorrow.
f_inscreenname 06-21-2012 07:03 PM
What ever you come up with just keep in mind motors don't like to stay at the same RPM for long periods of time. Move that stick around every now and then.
blefever 06-21-2012 07:36 PM
For me and my Baja, cruise speed depends on safety and comfort of passengers.
For my pontoon.....wfo all day long............. "Are we there yet"
302Sport 06-21-2012 08:34 PM
A lot of it depends on the build of the motor. I know mine have a 6100 limiter so I think 4000 or right below is a good cruise....
Dave M 06-21-2012 09:08 PM
My boat likes 3500-4000 better.
Dean Ferry 06-21-2012 09:29 PM
depends on the boat + power. For our 388, 3500 rpms seems to work real well. In the hdrostream, it's about 3000 rpms, but it's a mod-tunnel hull also.
frankenstein 06-21-2012 09:38 PM
It varies for all. I run with twin outboards that do not like low RPM's. My top end is 5900-6100 RPM's, but I cruise at 5400-5700. The motors are made for that. 5 boats ago, I would cruise at 4000 with a Merc outboard. It all depends.
