Got a warning by the law this weekend. Not happy
Have a 37' (at water line) Atlantic trawler. The boat is 13.5' wide, waighs 33,000lb dry. Holds 400gal of fuel, 200+ of water. It's powdered by twin detroits, draft is 4'. Full displacement hull. Was head back in came to the no wake zone. Boat it is idle with both motors in gear. Wildlife and fishires flash the flash light at me and yel show down. So I shut it to one motor. Still to fast. Flashed me once more. Yelled back I can't go slower. Then he said take it out of gear and coast the put it back in.
Now the boat wasn't throwing a wake to start with. Been by them time after time nothing said. Why is this time diffrent? Its going to make a 3-5" wake due to size and waight. Have the most control with both motors. On one motore the will pull but still to fast for the agent anyways. Take the boat out of gear. Then you have no control. What do you do? |
I, for one, have a hard time believing there is ANY law whatsoever in those parts. You must be joking, Casey! Lol.
Where was this at Casey ? Artie
Originally Posted by sommerfliesby
(Post 3731078)
It happend on the trickfaw river at the 22 bridge no wake zone. |
Before this become part of the conversation!
In legalese, the phrase "NO WAKE ZONE" means it is a speed zone. Like many others I have had boats which created virtually no wake at full or near full throttle. Not permitted!
To further the definition of No Wake Zone, in most states, and I looked up Louisiana and it is the same, is defined as (not verbatim) "as slow an operating speed as to maintain control and create no wake". I can find no definition of wake in Louisiana Law, not even in the Department of Wildlife and Fisheries. Now there are two issues: 1) What is a safe speed to control your Trawler? 2) By the true definition of wake, no object can go through the water without creating a wake! (fluid dynamics) I have been in areas where there is very sticky "speed/wake" enforcement. While using a 40' cruiser in those areas, I simply popped it in and out of gear. Still o.k. control and the smallest wake possible. A few years later the "No Wake Zone" was removed, right after the death of a local judge. Suppose there was any correlation to the two events? The other option might be to spend a lot of money and fight it... or armed with the definition of "fluid dynamics" ask the state to define wake and begin ticketing state boats who go through the speed zone, for creating a wake... since they have no definition of their own! |
I'm sure your solution is much better than any I would have, but it sorta sound like to me your, "getting into a piss'n match with a skunk". jus say'n
Jay |
Originally Posted by never enuff
(Post 3731271)
Jay |
fixx
like everywhere ellse in the u.s,,they are trying to generate money...this time it was a warning next time they will probably throw the book at you..
Ditto here, Casey - Sunday, we were out on Tickfaw River also at Hwy 22, got pulled over, we were in a 41 SeaRay with twin diesels. LA W & F agent was cordial, but stated it was a no wake zone. Both engines were at idle in gear. After the agent came on board we took one out of gear and we were still going to fast - at that point started shifting each in and out of gear, and drifting side to side in the river. Again the agent was very professional, however not sure how slow to go
Originally Posted by craig@GCOffshore
(Post 3733150)
| All times are GMT -5. The time now is 05:17 AM. |
