milky oil again !!
Head gasket or possibly the heads themselves. Had same happen to me and was corroded water passages on aluminum heads. Can't say that I've ever read of milky oil problems fixed successfully without tearing down the motor. I don't think you have any choice but to tear down the whole motor. Don't keep running it.
Start with the simple things first.
I had a hell of a time with milky oil. The culprit was high water pressure pushing the intake gasket.
It was a PITA to figure it out. I ended up getting water psi gauge, and found out I had over 30# of water PSI at high speeds.
I would think if the oil cooler was bad, you would lose oil, and not gain water.
I would presurize the cooling system, and see if it bleeds. I rented a radiator cap tester from Oreillys. Had to modify it a bit, but it was pretty easy. Blocked off the cooling system on the motor, and pumped it up to make sure it was good.
After that I'd do a leak down test.
Great info guys ! those are the things ill be getting started on here in a bit , going to start with the oil cooler and risers then the intake and heads , of couse a comp test as well , Ill keep you posted.. I do have very high water psi about 25 /30 psi at wot.. I did have some oil in the exhaust thought so really leaning towards a cooler... I hope!
well so far not so good , all tore down to one head left and so far nothing found , Comp test showed 150 psi on all 8 cylinders , risers good , oil cooler good intake ok , ...... man i hope i find it in the next head...
Could you see anything on the plugs? That could have shown which bank to start with
Hate hearing about things like this, ;(
This Cat is trying to keep up with the Big Dogs
