Sterndrive Oil Reservoir
Old 08-05-2012 | 09:06 PM
Default Sterndrive Oil Reservoir
Hi everyone, I recently got another boat and the oil Reservoir mounting bracket was broken so they wire tied it to a hose. My question is, the hose comes out of the Reservoir and then goes about 8 inches high then drops back down and heads to the gimbal housing. Is this system gravity feed? If so then i need to shorten the hose. I think it probably wouldnt be a bad idea to do that anyways right? Thanks
jbizub5192 is offline
Old 08-06-2012 | 07:12 AM
as far as I know it is gravity fed, the hose shouldn't go above the reservoir.
pstorti is offline
Old 08-06-2012 | 10:27 PM
Ok thanks, thats what I thought but just wanted to double check.
Old 08-07-2012 | 07:46 PM
waybomb's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Active Streak: 90 Days
What drives?
waybomb is offline
Old 08-07-2012 | 09:56 PM
1994 Mercruiser Alpha one gen 2
Old 08-18-2012 | 11:48 PM
I took the loop out of the hose so now it should flow freely by gravity. What I did notice was that when I had the bottle full with gear oil and had the hose completely off of the fitting hardly any gear oil came out. I then took the bottle off of the boat and was able to completely turn it downward and only a very very small stream would come out(sometimes it was so small it almost stopped). I then figured I would dissemble all of the internal part to clean then but even after I did that it was the same thing. So im wondering if the lower unit does suck the fluid out of there by vacuum or do I have a defective bottle? Thanks!
