Setup For Weiand 177 On 454 >
Old 08-10-2012 | 10:55 AM
Thanks for the help!
CenturyUltra is offline
Old 08-10-2012 | 10:57 AM
Default my 454sc
Lunati cam 02006
specs
valve lift .553 .571 (1.7 rocker ratio)
lobe lift .325 .336
adv dur .283 .293
dur @ .050 .236 .246
center line 112* 116*
lobe sep. 114*
rpm range 2700-6700
850 holly jet size 87 & 90
4 years running no top end damage keeping it below 4800rpm.
Went through port motor this year #4 main bearing bad, one lobe on cam .030" wear (flat tappet) valve spring was binding 600+lb. to compress.
Less rpm longer it will last. More rpm more mph. I run 2800-3500rpm all day (ICW).
30ftpanther is offline
Old 08-10-2012 | 12:24 PM
blue thunder's Avatar
Originally Posted by CenturyUltra
I've got a weiand 177 on a 454 mag in an 88 Formula 242ls. Motor is fresh and just broken in 4 bolt main forged internals 7.75:1 compression inconnel vales in steel heads with blower and carb off an old 525sc. Carb is a 1050 dominator. Boat only runs 62 mph gps with a 25p mirage plus prop at 30 degrees timing and 4800 rpm and 5lbs of boost. . It seems to run very rich the exhaust is getting the swim platform dirty everytime I take it out. I ran it before with a 23p mirage plus and it would turn too high 5500 at ~7lbs of boost but ran ~65 mph. I want to keep a safe tune most importantly but what can I do to increase speed and how fast should it run? More boost more timing? Thanks
I run 102 jets all around in my doms on 177s w/4.5pvs. Only very light soot on the transom and it is all the way to the bottom of the transom so I know it is at wot where I don't mind it. 98s gave me a/f readings 11.8-11.9 in summer so I think you are good there. You may be over rich in the idle circuit. Is the transom only sooty to the water line?
blue thunder is offline
Old 08-10-2012 | 12:28 PM
Originally Posted by 30ftpanther
88 scarab 30ft. twin 454, mercruiser weiand 177, 6lb. boost,
9.0 to 1 or 9.5 to 1 compression? 850 holley, 29p prop.
27degrees timing, 62mph gps at 3800rpm, rev limiter set at 4700rpm.
Runs a little rich at idle not bad.
dyno 2500rpm 603tq 305hp
dyno 4500rpm 540tq 460hp
hp still climbing at 4500rpm (cam lift .573?)
That makes me feel bad for the bravo1s.
Rev limiter for reentry.
I'm curious what you get for wot speed? We have same boat and similar power it appears.
Old 08-11-2012 | 01:26 AM
Lunati cam 02006
specs
lobe lift .325 .336
adv dur .283 .293
lobe sep. 114*
rpm range 2700-6700
You are wasting a lot of potential HP by only running 4800rpms with that cam. You may be saving the springs a little bit, but everything else has to work harder. That cam is designed to make its power at higher rpms on a 454. You would make more torque and HP with the smaller stock 525SC cam at 4800rpms.
Griff is offline
Old 08-13-2012 | 08:29 AM
My soot is on top of the platform so it must be at idle
Old 08-13-2012 | 11:56 AM
Its takes some tweaking of the 4 corner air bleeds screws to get the idle set just right.
Set it up to idle at about 850rpms in neutral.
You have to do it on a completely warmed up engine.
Griff is offline
Old 08-14-2012 | 09:35 AM
Check your float level, fuel pressure,power valve.
Old 08-16-2012 | 11:43 AM
I pulled the supercharger off to change the pulley and change the oil and noticed fuel in the oil. I just put new bearings and seals in it but never marked the rotor postion (to one another) on the gears. Do I just put them directly horizontal and vertical to each other? The gears can only go on the rotors one way and I see marks on the gears but if you line them up the rotors would hit. Thanks
Old 08-16-2012 | 03:32 PM
http://www.holley.com/data/TechServi...ech%20Info.pdf
weiand sc tech info web page
tech # 270-781-9741
