Setup For Weiand 177 On 454 >
Old 08-16-2012 | 06:01 PM
Default Dialing in a blower motor
Originally Posted by HTRDLNCN
Whats your A/F looking like?
Figure out a way to determine your A/F ratio. Should be 14:1 at idle, 13:1 midrange and 11.8to 12.0 wide open. The only way to determine this is with a meter. Everything else is guesswork. Good Luck.
Boxer is offline
Old 08-16-2012 | 08:43 PM
blue thunder's Avatar
Exactly correct as long as you are not too close to the edge of detonation with the engine build/boost.
blue thunder is offline
Old 08-17-2012 | 08:23 AM
Originally Posted by CenturyUltra
I pulled the supercharger off to change the pulley and change the oil and noticed fuel in the oil. I just put new bearings and seals in it but never marked the rotor postion (to one another) on the gears. Do I just put them directly horizontal and vertical to each other? The gears can only go on the rotors one way and I see marks on the gears but if you line them up the rotors would hit. Thanks
You have to line up the marks. The gears are mitered so the rotor will hit until you get the gears seated to one another. Fine tuning of rotor timing is done with shims under the miter gears. Make sure those go back just like they came out or you will need to retime the blower.
