My first alarm
Old 08-20-2012 | 12:35 AM
Originally Posted by VtSteve
It wasn't constant, about once every minute or so. I had always wondered how loud they are, THEY ARE LOUD! Thankfully, I made it to the dock, even if the bow was almost impaled on a windlass.
I've heard about bad idle control valves, is that what the IAC is?
Yes, and when they go completely bad, the alarm will beep every minute or so.
Griff is offline
Old 08-20-2012 | 12:57 AM
Rwbrew3's Avatar
You can check it before changing it by disconnecting and then starting, your idle speed should rise as normal, reconnect and start again, if your idle speed is normal it's probably not the IAC.
Rick
Rwbrew3 is offline
Old 08-20-2012 | 05:13 AM
Rick
I'll have them check it today, from everything I've read, the IAC sounds like the culprit.
Hate the coincidence of having just gassed up and have the alarm go off inside of 2 miles. But no ethanol through this engine yet, and I don't think any alarm will go off for water or bad gas.
I'd rather it be a bad IAC than the gas
VtSteve is offline
Old 08-20-2012 | 12:42 PM
Rwbrew3's Avatar
Hope that's all is!
Rwbrew3 is offline
Old 08-21-2012 | 08:32 AM
It was the IAC. Runs like a charm now.
Thanks to all.
VtSteve is offline
Old 08-21-2012 | 01:17 PM
My cousin had two different boats with Merc's 6.1 (377) with an IAC going bad. Something wrongs when a control module without any moving parts goes bad.
PhatboyC is offline
