-   -   Race Engine rebuild (https://www.offshoreonly.com/forums/general-boating-discussion/284257-race-engine-rebuild.html)
CafeRacerPTY 09-06-2012 06:02 PM
here are more pics of the engine. It definetly needs a thorough restoration...
http://i1062.photobucket.com/albums/...6264AB49D3.jpg
http://i1062.photobucket.com/albums/...62587CA9D8.jpg
http://i1062.photobucket.com/albums/...6248965651.jpg
http://i1062.photobucket.com/albums/...6243AA072B.jpg
http://i1062.photobucket.com/albums/...6269E8C3C6.jpg
CafeRacerPTY 09-19-2012 10:21 PM
after much consideration, we have torn down the engine locally and decided to rebuild it with a standard carb/manifold set up.
Upon further inspection of the components once the engine was opened, here is what we found:
the block is a 454 gen IV bowtie tall deck, with 4.500 bore.
heads are GM high perf 118cc
flat top pistons
the crank is a crower with the following specs (which I hope someone here can help me identify)
http://i1062.photobucket.com/albums/...psc3e63e9c.jpg
http://i1062.photobucket.com/albums/...ps2e840f99.jpg
and these engravings, which i wrote down, as well
http://i1062.photobucket.com/albums/...psb55abccc.jpg
given that its a tall block and a bowtie, which is already 4.500 bore, I would like to install a 4.500 crank and 6.535 rods , which would make it a 572cid.
What are you guys thoughts on this? has anyone built up this set up before?
Will i have to grind some clearance in the block for the 4.500 crank?
Thanks guys.
byrideroffshore 09-20-2012 06:37 AM
Cice prformance in Ohio has alot fo experience with that setup, Chuck had United racing engines in Miami, was the first builder for Victory team in Dubai.
