Drive showers
Old 09-21-2012 | 01:17 PM
Yea, top cap is hardcore. Cap was more than twice the size as my stock B1 caps. Lil pricey, but in the boating world, you get what you pay for IMO.
Got Cigs is offline
Old 09-21-2012 | 06:45 PM
GO4BROKE's Avatar
Lots of magazine testing here:
http://www.driveshowers.com/
under "Product Reviews"
The stock drive shower on the vee-bottom had a definite and positive effect compared to the test on the tunnel boat. It took out over 40 degrees in the cruising mode. When we tested the vee-bottom with the tip extension, we took out 48.2 degrees, but we still didn't reach the 50 degrees we were looking for. We felt the 48.2 degrees was as close as we would get with HOT BOAT's test equipment.
[img][/img]
GO4BROKE is offline
Old 09-21-2012 | 07:00 PM
pretty cool info. thanks
neeb_usmc is offline
Old 10-03-2012 | 02:16 PM
Cool
Interesting video I shot a couple weekends ago.. I have to make some adjustments to the drive shower it only works with the drive trimmed all the way down and at lower speeds.. With the drive trimmed up the shower stops working completely, and with it down there's enough wind back there it's blowing the water up and onto the transom instead of on the drive.
The 1st half the video is a 21 Schiada facing fwd in a consistent wind chop (wind 15-20 mph). 2nd half of the video is facing the drive.
http://youtu.be/3JFh5GxHRmU
RD
RiverDave is offline
Old 10-03-2012 | 03:32 PM
Smile
RD, unless you have the IMCO replacement cap,most drive showers are ineffective at high speeds .
Vacuum effect pulls spray away from the cap. But they do look good being there,lol.
spectras only is offline
Old 10-03-2012 | 04:27 PM
With the high X dimension most boats are running these days it puts the pick-up tubes too high to get any water into them. When the propshaft is even or higher than the bottom of the boat, I can see how no water gets into the shower. This is why we have low-water pick-ups for cooling water.
ondtip is offline
Old 10-03-2012 | 04:41 PM
that's the reason the Imco drive's top caps are plumbed in. If I had high X dim on my boat ,water pickups just for the drives on the transom would be my choice.The benefit of drive longevity would be more important to me than any performance loss casued by friction.
Old 10-03-2012 | 06:02 PM
Since we are talking about drive showers.... are there any showers for Alpha SS drives? Or do i need to modify one for it and if so which would be the best to modify?
chrisf695 is offline
Old 10-03-2012 | 06:12 PM
GO4BROKE's Avatar
The Simrek® Multiport Drive Shower ®
Order online using our secure server
Visa and MasterCard Credit Card Orders accepted
SUMMIT
HALO®
55 degrees
65 degrees
COOLING PROTECTION
11
15
DUMP PORTS
X
Stock Alpha(s) All
X
Alpha twins with a tie bar
X
All new style Bravo 1s, 2s and 3s
X
All old style Bravo 1s, 2s and 3s
X
Bravo(s) with a drive temp sending unit
X
Bravo(s) with steering stabilizers (bearing cap mount)
X
All Bravos with Imco, Latham or Fountain Steering (inspection cap mount
[img][/img]
GO4BROKE is offline
Old 10-03-2012 | 06:13 PM
GO4BROKE's Avatar
[img][/img]
GO4BROKE is offline
