More On 383's
Old 09-30-2012 | 10:53 AM
Originally Posted by bobl
Merc 6.2's use 5.7 rods & hyper pistons. Scorpions do also. Yes, 6.0 rods give a better rod angle and of course forged pistons are better, but for his application this build should work fine. I don't think you're far off on your build, just don't want to spin it to high RPM. No way should that cam cause reversion, even with stock exhaust. If I remember from our conversation, you have a Mefi 3 computer so tuning is not a problem. Just for the record I can dyno the engine in or out of the boat, with full wet exhaust. I also have a riser for the stainless exhaust with an 02 bung. If you opt for the EMIs be sure and get an 02 bung welded in.
Bob Lloyd
Full Throttle Marine
I will pretty much the same set up (carb ) (bob Madara cam) , would I be ok revving up to 5200 rpm?
Diego9040 is offline
Old 09-30-2012 | 12:31 PM
Lightbulb
FWIW, I have two 6.2's [ 2003 engines] with Smart Craft in my boat with over 200hrs. Mercrusier set the rev limiter at 5150. Dustin Whipple could probably raise the ECM555's limit to 5300 and the engine would still be safe.JMO
spectras only is offline
Old 10-01-2012 | 11:31 AM
The numbers on the back of the ECM is 16236999 and according to Marine Power Service its a MEFI-3 (for marine use). Was told it can be reprogramed with no problem. So what do you think ? Am I still ok.
01scarab29 is offline
Old 10-01-2012 | 12:08 PM
Yep, you're good.
bobl is offline
Old 10-01-2012 | 07:47 PM
I have seen pictures of your boat, looks really nice, congrats and thank for your input.
Old 10-01-2012 | 07:51 PM
Default fixx
is it black and silver with cooling fins or is it all silver..also what do the plugs look like?..
FIXX is offline
Old 10-02-2012 | 07:59 AM
Mrfixall ,, its all black , fins on top , with multi pin plug on both sides ,,, i cant add picture because company comp. i could send to cell phone.
Old 10-02-2012 | 03:47 PM
Default fixx
yes its a mefi..you must have pre 2001 engines..
FIXX is offline
Old 10-02-2012 | 04:31 PM
yeah could be ,,, all i know is its a 2001 29ft Scarab twin 5.7's MPI ,,, i bought from original owner with 130/132 hrs on engines,,,,
Old 10-02-2012 | 07:23 PM
Default Re: MEFI 3
Mid year production with 2000 production engines, IDK. Your engines can be easily tuned to support your project/
tunertech is offline
