question for you...
Old 07-12-2002 | 12:07 PM
Official OSO boat whore
Default question for you...
Say, is anybody running a Imco low mount alternator and ps bracket? I have the ps pump mounted, but the lower stud is too short to put a nut on it. I was wondering how your setup is configured. Anybody know of a longer stud?
Cord is offline
Old 07-12-2002 | 02:14 PM
Ok, I talked to IMCO and they said that they've never run into this problem before. Apparantly all the other studs in the world are longer than mine is. Of course, they also told me months ago that there was no way to tension the ps pump either. I guess these guys arn't too familiar with their product. Is anybody able to help me here?
BTW-the pump is stock off of a '88 454 mag.
Cord is offline
Old 07-12-2002 | 04:40 PM
pachangalpina's Avatar
Cord,
I recently purchased the IMCO bracket to replace my Merc part and had no problems with the mounting stud. I did have a problem with the low pressure line interfering with my stringer. I had to remove the curved tube and braze a straight one in its place. I do believe the stud is replaceable and is used to hold the tank onto the pump. Has yours been shortened? I have an old pump that I can remove the stud from if you need it.
Todd
pachangalpina is offline
Old 07-12-2002 | 05:26 PM
Any interest in trading? My stud is a stock merc, so there must of been a change over the years.
Cord is offline
Old 07-12-2002 | 05:46 PM
Mine is from '89 330 bravo and worked fine but I was not the original owner. Things have a way of changing over the years. I am in the process of moving to the lake this weekend so it will be sometime late Sun before I will be able to get back to you. The spare is at the shop and I will check it out when I am there.
Todd
Old 07-12-2002 | 06:13 PM
Hmmmm. Mine is close to that year also. Maybe, I'll measure the length tonight and post the data.
Cord is offline
Old 07-12-2002 | 11:58 PM
Audiofn's Avatar
Charter Member #232
Cord din't I give you that thing? Now you know why. I got so damn frustrated with it that I gave up. They were TOTALLY USSELESS with ANY tech help. NO one has ever had a problem they told me yada yada yada. Well I guess that makes two at leaste
Jon
Put your best foot forward!
Audiofn is offline
Old 07-13-2002 | 11:07 AM
Yes, their support is less than acceptable. Hell, if you don't know the correct answer don't BS me!
Cord is offline
Old 07-13-2002 | 11:34 PM
You have mail!
Cord is offline
Old 07-15-2002 | 08:53 AM
Well my spare has a 1/2" long threaded stud but the one on my boat is at least 1/2" longer. I feel your pain. Everything that I have done on my project has been the same way, I just got lucky on this part. Since this just screws in, can you not try using a threaded rod with a nut? Or find long bolt to go thru the bracket then a spacer and into the pump body.
Todd
