Sanding a lower unit for speed >
Old 02-10-2013 | 09:50 AM
  #51
Originally Posted by 4bus
I agree. I often wonder how much can be done with a stock bravo lower, however I wouldn't have a clue where to start.
Amazes me how smart most people in the sport are about engines, and how dumb most of us are about hydro dynamics.
+1...but we are not alone...from what i read everywhere,even the big companies are still learning..didn't i read that brand ''X'' outdrive will slow you down and has to be blueprinted/modified to perform better?
pqjack is offline
Old 02-10-2013 | 10:13 AM
  #52
Originally Posted by tomas_wallin
I just added a Hydromotive nose cone to my XR lower. It's also straightened, sharpened and a bit thinned.
I also got rid of the lower intake and modified the side intakes to make it work with the prop shafdt depth I'm at (3-1/2")
I'm going to leave it like this with no paint until l have tested.
It's wet sanded just like the bottom to a certain fine grit that according to a VERY reputable European boat designer works the best.
No low water pick up? I thought the low water pickup was faster than the dual water pickup?
Keith Atlanta is offline
Old 02-10-2013 | 10:46 AM
  #53
Originally Posted by 1989mach1
I was looking in to the speed nose cones for the bravos and thay r trying to say a 3 to 6 mph gaine with them. could that be
No way. You will not see 3-6 mph, the most u will see is 2 but probably a mph will be gained to be honest. You wont see any speed increase unless your running over 60 mph
Orionsilverboat is offline
Old 02-10-2013 | 11:04 AM
  #54
i got 82 last summer with a bad motor runing off 7. i had a roller lifter blow apart on me. if i could see 85 or up with both motors with fresh tops and full rebuld on the bad motor with the cones i will get them
1989mach1 is offline
Old 02-10-2013 | 11:12 AM
  #55
also im looking to leave mine bare this year so will there be a way to get the cones to look right with out pant? or will it just be better to save for shortys and run the bravos as thay r for now?
Old 02-10-2013 | 11:47 AM
  #56
tomas_wallin's Avatar
No and No! The low water pickup disturbs the water quite a bit.
tomas_wallin is offline
Old 02-10-2013 | 12:07 PM
  #57
looks relly good.
